Hello Team,
I have added capacity planning graph dashlet to my dashboard and scheduled report using schedule page option.
In dashlet, I have disabled few parameters like "Predicated" ,"Warning", "Fit" etc.
But all the options are enabled when I get report. How can I get report only with the options (Observed, Critical) I want?
Attached graph for better understanding
Capacity Planning Graph problem
sureshkraj2012
Re: Capacity Planning Graph problem
This functionality is not available as of now. You are welcome to post a feature request on our bug tracker here:
http://tracker.nagios.com/
or I can post one internally (if you want me to). Thank you!
