NagiosXI Install Problems
maite.rasche
Post by maite.rasche »
Redhat 6.6
64bits 2.6.32-504.el6.x86_64
Manual install of Nagios XI 2014 r2.0
Clean install of Redhat, no proxy in use
I´m trying to install Nagios XI on a Redhat 6.6 with a clean-minimal install and it fails checking the prerequisites.
Error: Package: nagiosxi-deps-2014r2.0-1.noarch (/nagiosxi-deps-2014r2.0-1.noarch)
Requires: perl(Net::SMTP::TLS)
Requires: perl(Crypt::Rijndael)
Requires: perl-Net-SNMP
Requires: pymssql
Requires: fping
Requires: php-pecl-ssh2
Requires: perl-Mail-IMAPClient
Requires: php-mssql
Requires: perl(Mail::POP3Client)
It´s registered to our RedHat Satellite to the oficial channels.
I added the optional child cannel but the error continues.
Could anyone help me?
lgroschen
Re: NagiosXI Install Problems
Post by lgroschen »
I'll go through your install log, can you type perl -v from your command line and add the output here
/Luke
maite.rasche
Thank you very much for your answer.
I´ve already solve the problem. I ´d no access to Internet and it was mandatory to access to the repositories.
Now I have complete the installation.
lgroschen
Post by lgroschen »
OK! Glad it's working. Please post here again if you need anything else.
Locked.
/Luke
