How to Modify SNMP community name
cdrussell
Post by cdrussell »
Need instructions on modifying snmp community name for service configured under host
Re: How to Modify SNMP community name
Post by slansing »
You need to modify it on the nagios configuration side correct? You should be able to change it under CCM > Services > (service name). It will likely be in one of the ARG slots, or it could be hardcoded into your command depending on how you set things up.
cdrussell
Post by cdrussell »
thanks. that helped isolate it.
