Left Hand Pane
emartine
Left Hand Pane
Post by emartine »
Is there a way to modify the left hand pane that has Quick View, Details, Performance Graphs... etc. My guess is that I may have to modify the html
I am looking to hide the Monitoring Process section since I don't want folks to start/stop or disable/enable, etc globally.
abrist
Red Shirt
Re: Left Hand Pane
Post by abrist »
emartine wrote:I don't want folks to start/stop or disable/enable, etc globally.
What permissions do you give those folks?
emartine
Re: Left Hand Pane
Post by emartine »
I've given them user with some evelated privs. I don't want them to even see it even if they can click with a permission denied.
abrist
Red Shirt
Re: Left Hand Pane
Post by abrist »
Well, you may be able to remove them from the list, but this will not be multi-tenet as it will be missing for *all* users. Is that ok?
emartine
Re: Left Hand Pane
Post by emartine »
That should be fine as admins have access to the command line.
abrist
Red Shirt
Re: Left Hand Pane
Post by abrist »
Well you could hide the link, but add the link to a dashboard/view for the admins so that they can still see it.
Edit the file:
/usr/local/nagiosxi/html/includes/utils-menu.inc.php
Comment out the lines #1945 - #1995:
    /*add_menu_item(MENU_HOME, array(
        "type" => "menusection",
        "title" => gettext("Monitoring Process"),
        "id" => "menu-home-section-monitoringprocess",
        "order" => 600,
        "opts" => array(
            "id" => "system",
            "expanded" => true,
            //"url" => $nagioscoreui_path."extinfo.php?type=0"
            "url" => $xistatus_path . "?show=process"
        "function" => "is_authorized_for_monitoring_system",
        "type" => "link",
        "title" => gettext("Process Info"),
        "id" => "menu-home-processinfo",
        "order" => 601,
        "opts" => array(
            //"href" => $nagioscoreui_path."extinfo.php?type=0"
            "href" => $xistatus_path . "?show=process"
        "type" => "link",
        "title" => gettext("Performance"),
        "id" => "menu-home-performance",
        "order" => 602,
        "opts" => array(
            //"href" => $nagioscoreui_path."extinfo.php?type=4"
            "href" => $xistatus_path . "?show=performance"
        "type" => "link",
        "title" => gettext("Event Log"),
        "id" => "menu-home-eventlog",
        "order" => 603,
        "opts" => array(
            //"href" => $nagioscoreui_path."showlog.php"
            "href" => $xireports_path . "eventlog.php"
Browse away from the page and browse back. The links should now be missing. If the user knows the GET request for it, they could still bring it up. But this will stop vagrants.
emartine
Re: Left Hand Pane
Post by emartine »
Excellent. I am assuming I can do the same for the Auto-Discovery Wizard? I removed the wizard but the link remains and it is dead.
Click on the link results in the page:
Installation Problem
An installation errror was detected. The following steps must be completed before using this component:
Run the setup script. To do this, login to the Nagios XI server as the root user and issue the following commands:
chmod +x /usr/local/nagiosxi/html/includes/components/autodiscovery/setup.sh
sreinhardt
-fno-stack-protector
Re: Left Hand Pane
Post by sreinhardt »
Yes, you can alter that as well. Since I have not seen it mentioned. I want you to be aware, all of this will be overwritten on update. We always force a complete overwrite of the html directories, so these changes will have to be made again if you wish to keep it this way.
emartine
Re: Left Hand Pane
Post by emartine »
I can't seem to find the section for removal of the auto-discovery wizard link.
abrist
Red Shirt
Re: Left Hand Pane
Post by abrist »
Did you remove the auto-discovery component and wizard?
