Server sending email to itself
rajasegar
Post by rajasegar »
Nagios XI 2014R1.5
Can you please advice from where is this email triggered and how to disable it.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Re: Server sending email to itself
This doesn't look like any typical ("default") XI notification, for example:
***** Nagios XI Alert *****
Nagios has detected a problem with this host.
Notification Type: PROBLEM
Host: CentOS-NCPA
State: DOWN
Address: 192.168.x.x
Info: a
Date/Time: 2014-11-19 08:39:54
Do you have a service named "PostgreSQL Backup Log for PDS1131"? Does this email exist in your configs?
grep -R root@PDS1131 /usr/local/nagios/etc/
rajasegar
Post by rajasegar »
lmiltchev wrote:This doesn't look like any typical ("default") XI notification, for example:
Host: CentOS-NCPA
State: DOWN
Info: a
No service named PostgreSQL.
Returned nothing.
Could this be the cron backup job?
RHEL 6 & 7
It is possible. Or it could be a "custom" report... not sure.
What do you have in the cron.d directory?
ls -l /etc/cron.d
Check what you have in these files.
You can check the root, apache, and postgres crontabs:
crontab -l
crontab -u apache -l
crontab -u postgres -l
rajasegar
Post by rajasegar »
ls -l /etc/cron.d
crontab -l
I did not configure any custom report on this server
[nagios@PDS1131 ~]$ ls -l /etc/cron.d
total 20
-rw-r--r--. 1 root root  113 Sep 12  2013 0hourly
-rw-r--r--. 1 root root  139 Oct  3  2012 mrtg
-rw-r--r--  1 root root 1488 Oct 16 10:00 nagiosxi
-rw-r--r--. 1 root root  108 Apr  7  2014 raid-check
-rw-r--r--. 1 root root  235 Sep 17  2013 sysstat
[nagios@PDS1131 ~]$ cat /etc/cron.d/nagiosxi
# /etc/cron.d/nagiosxi: crontab fragment for nagiosxi
# Backup MySQL & PostgreSQL Databases
0   7 * * * root   /root/scripts/automysqlbackup
0   8 * * * root   /root/scripts/autopostgresqlbackup
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php > /usr/local/nagiosxi/var/dbmaint.log 2>&1
*   * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1
01  * * * * nagios /usr/local/nagiosxi/cron/recurringdowntime.pl > /usr/local/nagiosxi/var/recurringdowntime.log 2>&1
*/5 * * * * nagios /usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php > /usr/local/nagiosxi/var/deadpool.log 2>&1
[nagios@PDS1131 ~]$ sudo crontab -l
no crontab for root
[nagios@PDS1131 ~]$ sudo crontab -u apache -l
#crontab for apache user
[nagios@PDS1131 ~]$ sudo crontab -u postgres -l
no crontab for postgres
RHEL 6 & 7
This is from the cron
Which performa a daily backup of the postgresql DB
rajasegar
Post by rajasegar »
scottwilkerson wrote:This is from the cron
Thanks, changed the mail from log to stdout.
RHEL 6 & 7
