failed to open socket /var/lib/nagios3/rw/live: Permission d
murali969
Post by murali969 »
Hi All,
Please help me on this below while configure thruk livestatus and i got a below error
Can some on help me on this
Server version :Ubuntu 12
Nagios version 3
failed to open socket /var/lib/nagios3/rw/live: Permission denied at lib/Monitoring/Livestatus/Class/Lite.pm line 263 at lib/Monitoring/Livestatus/Class/Lite.pm line 263 (/var/lib/nagios3/rw/live) Errors detected
Murali
rhassing
Re: failed to open socket /var/lib/nagios3/rw/live: Permissi
Post by rhassing »
Is it possible for the user that runs nagios (usually nagios) to write in this directory?
Rob Hassing
murali969
Post by murali969 »
Hi
Thanks for your reply,
Nagios core is working fine but this thruk failed to open socket
Murali
rhassing
Post by rhassing »
Does "/var/lib/nagios3/rw/live" exist? What are the permissions?
Rob Hassing
murali969
Post by murali969 »
no /var/lib/nagios3/rw/live in the server
Murali
Combined your double post..
Hi
Please let us know how to configure livestatus and backend
Murali Muppa
Post by slansing »
We do not directly support Livestatus or Thruk. They have their own, separate, support channels for integration/support/configuration which I suggest you check.
