Dear Team,
Please check Windows is showing Virtual memory instead of Physical memory. I also changed mentioned parameter which is suggest for NRPE MEMUSE. but still it was showing Virtual memory on the NagiosXI dashboard.
Please help us to get Physical Memory instead of Virtual Memory in Windows Servers.
Windows showing wrong Physical Memory
Re: Windows showing wrong Physical Memory
You need to provide us with more information, please post the exact command you are using to check the windows system so we can take a look.
Also, what version of windows is this.
Hi team,
Please check the below link as I have followed and got wrong memory in nagiosxi console.
http://support.nagios.com/forum/viewtop ... =7&t=24911
Please also check the attached screenshots which we have taken from Windows Server 2008 R2 and NagiosXI.
Please suggest
Thanks in advanced
Please suggest
Thanks in advanced
Are you allowing arguments in NSClient as per the first link?
http://support.nagios.com/forum/viewtop ... 911#p84947
- Box293
- Too Basu
What is the version of NSClient++ running on the windows box?
/usr/local/nagios/libexec/check_nrpe -H 152.63.1.57As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Dear Team,
Yes we allowed argument in nsc.ini file in windows system.
Can you also answer @Box293's question regarding the version?
