Best practice - should we turn off any of these ports?
PhilG
Post by PhilG »
Hello:
I had my security guy check to see if we are applying good security practices and had him run a scan against our Nagios XI monitoring server.
He identified the following:
For the most part things look good. There are a few open ports that I would question both why they are open and what is using them.
Those ports are:
5666
8400
8402
9998
There are more ports open of course, but they are easily identified (ssh, apache, ntp, etc..)
I am noting that it's obvious that we would need to allow for port 5666 for NRPE checks, but what would you suggest to keep and/or close - I'm thinking at least 9998 should be?
Thank you.
Newbie '14
Re: Best practice - should we turn off any of these ports?
Yes, tcp port 5666 is for NRPE checks,(usually it's open on the client box that you are monitoring via NRPE). I am not sure about the rest of the ports, but you can probably run nmap against these ports and try to identify what they are used for...
nmap localhost -p <port number>
for udp ports
nmap -sU localhost -p <port number>
PhilG
Post by PhilG »
You may freeze this post.
Newbie '14
cmerchant
Post by cmerchant »
We'll go ahead and close this thread. Thanks.
