SNMP V3 Polling on Cisco ASA 5500
AMacintosh
Post by AMacintosh »
We are not able to successfully monitor Environment attributes for Cisco ASA using SNMP V3 Polling. We have Memory and CPU polling in place but we are unable to get the fan status,power supply, temp checks working. Any help would be greatly appreciated.
sreinhardt
-fno-stack-protector
Re: SNMP V3 Polling on Cisco ASA 5500
Post by sreinhardt »
What settings do you have currently on the cisco device? If other oids are polling correctly, but these are not, my initial thought would be that the cisco device has that portion of the snmp tree locked from your particular snmp user account.
AMacintosh
We eventually got the check_nwc_health script to check the environment successfully on the devices. The output isn't very descriptive but nonetheless it is polling.
cmerchant
Post by cmerchant »
Would you like us to go ahead and close this thread?
