Applying configuration fails
accoward
Post by accoward »
Apply configuration is now failing. How do I find out what is causing this to fail? Is there a log?
The /var/log/mysqld.log has the following last entry: "110810 13:37:39 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_systemcommands' is marked as crashed and last (automatic?) repair failed"
Not sure if this is causing the configuration failure or not.
Thanks.
:D
nscott
Re: Applying configuration fails
Post by nscott »
Something that might help is this:
http://support.nagios.com/wiki/index.ph ... s_Stale.22
Its supposeed to be for when the event data is stale, but this also applies as it looks like your database has gotten corrupted somehow.
Nicholas Scott
