I am needing to have the Executive Summary Report list the availability pie graph excluding downtime that was scheduled. I can go to the availability report and set the "Hide scheduled Downtime" option from the advanced options, but this option is not available in the executive report. I don't really need the option to be select-able as long as it don't count the scheduled downtime by default. Thank you for your assistance.
Nagios XI 64-bit Centos VM deployment.
Executive Summary Report to exclude downtime
Re: Executive Summary Report to exclude downtime
It's a good idea. I posted an internal feature request (TASK ID 4541). Thanks!
Should I follow that request? What's the URL for the request?
The location of that feature request is internal, and it's ID was posted here for tracking purposes. You will not be able to view it unfortunately. If you'd like to, you can create your own at:
tracker.nagios.com
Which should be updated by the devs if/as they work on the feature.
tracker.nagios.com
