I am looking Triggered down time nagios setup on Unix/Linux for selected services across the many servers(100 Plus)..
example : We have mounted NFS mount across the 100 Plus Servers and monitoring the NFS file system through Nagios.. If any NFS file system down on any server we will get an alert..
We are looking for setup instructions to disable all NFS mounts monitoring during the patch on NFS master Server
Subbu
Downtime, triggered downtime for children and alert sounds
Re: Downtime, triggered downtime for children and alert soun
There are quite a few options when it comes to this, take a look at this list:
http://exchange.nagios.org/directory/Ad ... d-Downtime
I'd recommend a script that submits downtime to multiple hosts via the command pipe, some of the scripts above accomplish this.
