2014R2.0-Can not use graph template Highcharts is ON
questrad
Post by questrad »
How I understand, the graph template is working in following way.
The graph template name must be much the command name that is used in service.
Now, when Highcharts for Perfdata Graphs in ON - the graphs are not show as I have defined in template.
But as soon I disable it - the graphs are show as it defined in graph template.
Any suggestion?
Re: 2014R2.0-Can not use graph template Highcharts is ON
Do highcharts work with the other templates? What are the permissions on the template?
ls -l /path/to/the/template/
Run the actual check from the command line and show us the check and the output of it.
Post by Box293 »
questrad wrote:The graph template name must be much the command name that is used in service.
This is correct when using PNP graphs.
Highcharts does not currently have a template capability. It does not look at the PNP templates at all. I dream of a day when we can create templates with Highcharts :idea:
