NCPA 1.7.2 CPU 100%
AMacintosh
NCPA 1.7.2 CPU 100%
We are seeing an incorrect CPU Usage result on a Windows 2008 R2 server. It keeps reporting 100% CPU usage however the server perf mon log and Task Manager do not show this issue. When I look at the Top Processes tab in the agent on that server, it keeps flashing CPU Load: 100%. If at the same time, I have task manager open, I don't see this spike. There only appears to be one CPU on this VM.
Re: NCPA 1.7.2 CPU 100%
Can you run the following commands and show us the output?
On the Windows box (from the CMD)
On the Nagios XI server (from the CLI)
wmic cpu get loadpercentageCode: Select all
/usr/local/nagios/libexec/check_ncpa.py -H <client ip> -t 'token' -P 5693 -M cpu/percent -w 80 -c 90Be sure to check out our Knowledgebase for helpful articles and solutions!
AMacintosh
Please see the results...
Load Percentage
5
[]# /usr/local/nagios/libexec/check_ncpa.py -H 10.0.0.0 -t 'token' -P 5693 -M cpu/percent -w 80 -c 90
CRITICAL: percent was 100% | 'percent_0'=100%;80;90;
OK: percent was 2% | 'percent_0'=2%;80;90;
Load Percentage
5
So, the first check "failed", but the second one didn't. What is the output when you try to increase verbosity?
What is the value that you see in the API?
Can you upload the "ncpa_listener.log" from the Windows box, so that we can take a look at it?
/usr/local/nagios/libexec/check_ncpa.py -H 10.0.0.0 -t 'token' -P 5693 -M cpu/percent -w 80 -c 90 -vvvCode: Select all
https://clientip:5693/api/cpu/percentBe sure to check out our Knowledgebase for helpful articles and solutions!
AMacintosh
I ran the checks immediately right after each other and it shows that the value for CPU load is flapping between 100%. I'll check the API and the command line check with -vv and get back to you.
No problem.I'll check the API and the command line check with -vv and get back to you.
AMacintosh
Please see the results of 3 fast command line checks.
[root@nastisrnagap01 ~]# /usr/local/nagios/libexec/check_ncpa.py -H 10.0.0.0 -t 'token' -P 5693 -M cpu/percent -w 80 -c 90 -vvv
AMacintosh
The API is showing either 0% or 100% when refreshing.
Ideas?
Edit: NCPA listener log
Ideas?
Reason: Merged your posts, please edit your previous post rather than double posting.
Were you trying to attach your log? Does not look like it got through.
AMacintosh
Yeah it won't allow me to upload the log. here are the latest entries.
2014-12-03 08:15:13,773:INFO:handler:NagiosIP - - [2014-12-03 08:15:13] "GET /api/disk/logical/D:|/used_percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 325 0.000000
2014-12-03 08:15:14,319:DEBUG:handler:Initializing WebSocket
2014-12-03 08:15:14,319:DEBUG:handler:Validating WebSocket request
2014-12-03 08:15:14,319:DEBUG:__init__:Getting accessor: disk/logical/C:|/used_percent/
2014-12-03 08:15:14,319:INFO:handler:NagiosIP - - [2014-12-03 08:15:14] "GET /api/disk/logical/C:|/used_percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 327 0.000000
2014-12-03 08:15:14,756:DEBUG:handler:Initializing WebSocket
2014-12-03 08:15:14,756:DEBUG:handler:Validating WebSocket request
2014-12-03 08:15:14,756:DEBUG:__init__:Getting accessor: memory/swap/percent/
2014-12-03 08:15:14,756:INFO:handler:NagiosIP - - [2014-12-03 08:15:14] "GET /api/memory/swap/percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 317 0.000000
2014-12-03 08:15:20,357:DEBUG:handler:Initializing WebSocket
2014-12-03 08:15:20,357:DEBUG:handler:Validating WebSocket request
2014-12-03 08:15:20,357:DEBUG:__init__:Getting accessor: memory/virtual/percent/
2014-12-03 08:15:20,357:INFO:handler:NagiosIP - - [2014-12-03 08:15:20] "GET /api/memory/virtual/percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 317 0.000000
2014-12-03 08:15:44,898:DEBUG:handler:Initializing WebSocket
2014-12-03 08:15:44,898:DEBUG:handler:Validating WebSocket request
2014-12-03 08:15:44,914:DEBUG:__init__:Getting accessor: cpu/percent/
2014-12-03 08:15:45,927:INFO:handler:NagiosIP - - [2014-12-03 08:15:45] "GET /api/cpu/percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 315 1.030000
2014-12-03 08:20:13,782:DEBUG:handler:Initializing WebSocket
2014-12-03 08:20:13,782:DEBUG:handler:Validating WebSocket request
2014-12-03 08:20:13,782:DEBUG:__init__:Getting accessor: disk/logical/D:|/used_percent/
2014-12-03 08:20:13,782:INFO:handler:NagiosIP - - [2014-12-03 08:20:13] "GET /api/disk/logical/D:|/used_percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 325 0.000000
2014-12-03 08:20:14,641:DEBUG:handler:Initializing WebSocket
2014-12-03 08:20:14,641:DEBUG:handler:Validating WebSocket request
2014-12-03 08:20:14,641:DEBUG:__init__:Getting accessor: disk/logical/C:|/used_percent/
2014-12-03 08:20:14,641:INFO:handler:NagiosIP - - [2014-12-03 08:20:14] "GET /api/disk/logical/C:|/used_percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 327 0.000000
2014-12-03 08:20:14,984:DEBUG:handler:Initializing WebSocket
2014-12-03 08:20:14,984:DEBUG:handler:Validating WebSocket request
2014-12-03 08:20:14,984:DEBUG:__init__:Getting accessor: memory/swap/percent/
2014-12-03 08:20:14,984:INFO:handler:NagiosIP - - [2014-12-03 08:20:14] "GET /api/memory/swap/percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 317 0.000000
2014-12-03 08:20:20,553:DEBUG:handler:Initializing WebSocket
2014-12-03 08:20:20,553:DEBUG:handler:Validating WebSocket request
2014-12-03 08:20:20,553:DEBUG:__init__:Getting accessor: memory/virtual/percent/
2014-12-03 08:20:20,553:INFO:handler:NagiosIP - - [2014-12-03 08:20:20] "GET /api/memory/virtual/percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 317 0.000000
2014-12-03 08:20:44,891:DEBUG:handler:Initializing WebSocket
2014-12-03 08:20:44,891:DEBUG:handler:Validating WebSocket request
2014-12-03 08:20:44,891:DEBUG:__init__:Getting accessor: cpu/percent/
2014-12-03 08:20:45,905:INFO:handler:NagiosIP - - [2014-12-03 08:20:45] "GET /api/cpu/percent/?token=token&warning=85&critical=95&check=1 HTTP/1.0" 200 315 1.014000
