Can someone point me in the right direction to find the credentials for the 2015r1.1 VM? I've searched the forums and the documentation and do not see anything resembling credentials for this particular installation method.
Thanks in advanced!
Log Server OVA
Re: Log Server OVA
Your credentials should be in a banner when you first start the VM up, I just tested this on my end.
Re: Log Server OVA
Yes, I saw that literally seconds after I posted...the one place I never expected to look. Thanks. You may close this.
