Problem using Configuration wizards
tmelcher
Post by tmelcher »
When trying to use the configuration wizards the server appears to hang at "Waiting for configuration verification..........." the dots just keep on going and it never completes.
Applying Configuration
Command submitted for processing...
Waiting for configuration verification.....................................................................................................................................
Network Switch Monitoring Wizard
Configuration submitted for processing...
We are currently running Nagios XI 2009R1.1H
tonyyarusso
Re: Problem using Configuration wizards
Post by tonyyarusso »
I've had that happen once or twice, but when it did I just killed it and ran through things again and they worked fine. Can you confirm whether this is a consistently reproducible or intermittent issue for you?
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
