This support forum board is for support questions relating to
Nagios Log Server, our solution for managing and monitoring critical log data.
vmesquita
Post
by vmesquita »
First I realized that logs were taking a long time to show up. Then I was comparing the dates on the log server interface:
@timestamp host type message Actions
[b]2014-11-27T15:02:49.000-02:00 x.x.x.x syslog teste[/b]
2014-11-27T15:02:29.000-02:00 x.x.x.x syslog [origin software="rsyslogd" swVersion="5.8.10" x-pid="24040" x-info="http://www.rsyslog.com"] exiting on signal 15.
2014-11-27T15:02:29.000-02:00 x.x.x.x syslog Kernel logging (proc) stopped.
And this is from /var/log/messages
Nov 27 12:02:29 vx421 kernel: Kernel logging (proc) stopped.
Nov 27 12:02:29 vx421 rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x
Nov 27 12:02:29 vx421 kernel: imklog 5.8.10, log source = /proc/kmsg started.
-pid="24249" x-info="http://www.rsyslog.com"] start
Nov 27 12:02:29 vx421 rsyslogd: rsyslogd's groupid changed to 4
Nov 27 12:02:49 vx421 teste_log: teste
The Log Server previously had the timezone set incorrectly. This has been fixed but nothing changed. Any ideas?
- Too Basu
Post
by Box293 »
vmesquita wrote:The Log Server previously had the timezone set incorrectly. This has been fixed but nothing changed. Any ideas?
Did you update the system timezone AND the /etc/php.ini date.timezone setting?
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy.
vmesquita
Post
by vmesquita »
I just changed also php.ini and rebooted, nothing changed.
- Too Basu
Post
by Box293 »
Is the date/time/timezone correctly set on the sending device?
Privacy Policy.
