Copying Gauges dashlet
BanditBBS
Post by BanditBBS »
Ok...so I like the gauges dashlet but only want to output a table and not a gauge. So, easy way(at least I thought) would be to copy the gauge dashlet and just modify its output. I modify the in.php, getdata.php and the js file. I search and replace Gauge with Itc and gauge with itc. I upload the new dashlet just to see if the copy/rename itself works. When I do that it breaks XI complete and all pages come up blank until I remove the folder.
Any idea what I am missing in this that is stopping it from working?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Copying Gauges dashlet
Post by Box293 »
Easiest way to find out what is causing it to break is to:
tail -f /var/log/http/error_log
