Nagios Log Server on RHEL 6
krobertson71
Post by krobertson71 »
Our Linux admins break out our RHEL6 installs into separate partitions like so:
/boot
/var
/opt
/usr
/tmp
etc
What I need to know is where Log Server keeps most of it's data so I can tell them which partitions need to be what size. I understand the size depends on what I am collecting, I am just asking which partition(s) should I be putting the "bulk" of my capacity in. Or, if you have a recommendation on each of these then that would be helpful as well.
Re: Nagios Log Server on RHEL 6
Post by slansing »
If I am reading what you are asking correctly, it should be "/usr", more specifically, your indicies, and cluster data are stored in the elasticsearch directory tree at:
/usr/local/nagioslogserver/elasticsearch/data/<CLUSTER_ID>/nodes/<NODE_#>/
In addition, /var will grow quite a bit with both the current logstash.log, and it's tarred archives in:
/var/log/logstash
krobertson71
Yeah that is what I was looking for. So Logstash doesn't need a big store as well? And log files... are they going to var or within /usr as well?
Post by slansing »
That would be another good one to provide some additional space on, more specifically:
/var/log/logstash
As you had mentioned, that contains your current logstash.log, as well as the tarred archives. Apologies for not mentioning that in my original post, I'm hunting around with:
du -m --max-depth 1 | sort -rn | head -11
There is also an elasticsearch directory in /var which houses cluster snippets, I need to do more looking into the elasticsearch mechanics we run on logserver to say what is actually being moved or copied out, and what is not.
krobertson71
Cool keep my posted. I will do my research on this end.
cmerchant
Post by cmerchant »
Good info to know regarding file locations and space allocation. I suspect that this will be a good FAQ or doc to be added to the standard NLS documentation. Thanks.
krobertson71
Yeah I need more info I believe..
So lets say I will be collecting 100 gigs of log data...
How big should /var be considering logstash...
How big should /usr be considering elasticsearch and cluster/indexes etc are located..
krobertson71
actually I think most everything is in /usr
This is from my laptop running logserver in VirtualBox.
Here is /var compared to /usr. To me it looks like most of my space allocation needs to go to /usr. Tell me if I am wrong about this.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
I completely agree with krobertson. /var may raise somewhat in size, but the vast vast majority of files should be in /usr/local/nagioslogserver/elasticsearch/data as slansing correctly pointed out originally. Especially if logrotate is used with the logstash log, I would not expect it or it's rotations to grow too out of control.
bdgoecke
Post by bdgoecke »
For point of reference, on my test log server I have 3 lightly used linux machines loging to the server for a month or so..
_Cluster_Statistics_
1,357,738 Documents
287MB Primary Size
287MB Total Size
1 Data Instances
352 Total Shards
36 Indices
_Disk_Usage_
[@LogServer-centos65-64bit /]$ sudo du -sh *
5.8M    bin
88M     boot
220K    dev
29M     etc
488M    home
448M    lib
22M     lib64
16K     lost+found
4.0K    media
4.0K    mnt
4.0K    opt
179M    root
14M     sbin
4.0K    selinux
4.0K    srv
12K     store
0       sys
420K    tmp
1.4G    usr
346M    var
[@LogServer-centos65-64bit /]$ cd /var
[@LogServer-centos65-64bit var]$ sudo du -sh *
53M     cache
24K     db
8.0K    empty
4.0K    games
51M     lib
4.0K    local
16K     lock
226M    log
0       mail
4.0K    nis
4.0K    opt
4.0K    preserve
104K    run
112K    spool
4.0K    tmp
18M     www
4.0K    yp
[@LogServer-centos65-64bit var]$ cd /usr
[@LogServer-centos65-64bit usr]$ sudo du -sh *
30M     bin
4.0K    etc
4.0K    games
17M     include
232M    lib
109M    lib64
17M     libexec
695M    local
29M     sbin
292M    share
12K     src
0       tmp
