Migration problem when service is in a _multiple_hosts" file
rickwilson7425
This is an ongoing issue which Andy has helped us with before.
I have upgraded our test instance to NagiosXI 2014v2.0.
I am migrating from Core 3.5 to this version.
Most things come across fine but there appears to be a problem with migrating servicegroups.cfg entries when the associated service is contained in a "_multiple_hosts" file.
If I create the services contained in the _multiple_hosts file as individual services and then delete that _multiple_hosts file it will get past that point but fail on the next instance it encounters.
Thanks for your help.
Rick
Rick
Re: Migration problem when service is in a _multiple_hosts"
Don't you guys have 2 hours left of consulting? If so, you are welcome to claim it.
Could you give us an example of what the _multiple_hosts file contains?
rickwilson7425
Here is a small chunk of it:
service_description Forbind 24920 Process Count
host_name jpdcp2,jpdcp1,denpjpdcm20,denpjpdcm21
use generic-service-5
check_command check_nrpe_procs_generic!-c 1:1 -C forbind -u opscadm -a 24920
check_period 24x7
contact_groups gscc-group
event_handler_enabled 0
notification_period 24x7
service_description ingestNOTAM
check_command check_nrpe_procs_generic!-c 1:1 -C ingestNOTAM -u opscadm -a 25001
check_period 24x7
service_description ingestMTDD ui_domestic
check_command check_nrpe_procs_generic!-c 1:1 -C ingestMTDD -u opscadm -a ui_domestic
check_period 24x7
service_description ingestMTDD ui_motne
check_command check_nrpe_procs_generic!-c 1:1 -C ingestMTDD -u opscadm -a ui_motne
check_period 24x7
service_description Disk Space on /var
host_name dengjsis1,dengjsip1,dengjsip2,denbeffp1,denbeffp2,denplfmtp1,denplfmtp2
use hostgroup-service
check_command check_nrpe_disk_space!15%!10%!/var
contact_groups unix-admins
service_description JBoss Process Count:
host_name denbeffp1,denbeffp2
check_command check_nrpe_procs_by_user!1:2!1:2!java!jeppadm
check_period 24x7
notes_url http://confluence.jeppesen.com/display/TSS/AOCi+and+JSI
}Re: Migration problem when service is in a _multiple_hosts"
I am going to test this and get back to you.
Are you importing the configs in the correct order?
commands -> timeperiods -> contacttemplates -> contacts -> contactgroups -> hosttemplates -> hosts -> hostgroups -> servicetemplates -> services -> servicegroupsBe sure to check out our Knowledgebase for helpful articles and solutions!
rickwilson7425
Yes, as far as I can tell, I am doing that. We have 3 command files (coomands.cfg, misccomamnds.cfg, notificationcommands.cfg) so I am doing all those first and then right down the list.
When you didn't split the "_multiple_hosts" file, were you able to successfully import the services? If this didn't go well, the next step (importing servicegroups) would fail too. I tried to import the the services and got bunch of duplicates. I haven't tried splitting the file yet. I might do this later. What are the exact errors and warnings that you are getting?Most things come across fine but there appears to be a problem with migrating servicegroups.cfg entries when the associated service is contained in a "_multiple_hosts" file.
rickwilson7425
I haven't split the "_multiple_hosts". I'm not sure what you mean by that.
I don't get any errors until I try to verify the write of the files in CCM. This is an example of what I get: (the top of the message is the only thing relevant at this point, I think...)
Error: Could not find a service matching host name 'dencomp1' and description 'Disk Space on /WX' (config file '/usr/local/nagios/etc/servicegroups.cfg', starting on line 553)
Error: Could not find a service matching host name 'denship01p' and description 'FedEx Broadcast Service' (config file '/usr/local/nagios/etc/servicegroups.cfg', starting on line 428)
Error: Could not expand members specified in servicegroup 'shipping-prod' (config file '/usr/local/nagios/etc/servicegroups.cfg', starting at line 428)
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'Apache Process Count: PROD' on host 'denpap02' (config file '/usr/local/nagios/etc/services/denpap02.cfg', starting on line 169)
Warning: Duplicate definition found for service 'Apache Process Count: PROD' on host 'denpap02' (config file '/usr/local/nagios/etc/services/denpap02.cfg', starting on line 157)
Warning: Duplicate definition found for service 'Apache Process Count: PROD' on host 'denpap02' (config file '/usr/local/nagios/etc/services/denpap02.cfg', starting on line 145)
[color=#FF0000]****A LOT OF DUPLICATE ERRORS DELETED FROM HERE TO MAKE THIS SHORTER *****[/color]
sreinhardt
- -fno-stack-protector
The verify you are showing now, is saying that the following services could not be found:
host: dencomp1
service: Disk Space on /WX
host denship01p
service: FedEx Broadcast Service
It is also saying that one or more members in the service group shipping-prod is not able to be found(very likely one from above). I would suggest looking through the already imported configs for these service names, and looking through the multiple hosts config to see if they might have been dropped in there. I would also suggest taking a look at the current shipping-prod service group definition and find which member is missing.
host: dencomp1
host denship01p
rickwilson7425
I already looked through all that before I posted this message - there is nothing missing from the servicegroups. The services those messages refer to are found in one of the "_multiple_hosts" entries.
If I create those services as individual items in the database and then delete the "_multiple_hosts" entries associated with them it gets past those and fails at the next one it finds of the same type.
That is why I am saying that there seems to be a problem with the system associating servicegroup entries with services that exist in a "_multiple_hosts" entry.
- Nagios Support
We will have to do some more digging into this and will get back to you within the next 24 hours.
