CheckDriveSize Exclude Certain Disk
warnox
Post by warnox »
I want to know how to exclude a particular drive from the 'CheckDriveSize' command, in this case the Page File drive. The documentation doesn't seem very complete and doesn't have very detailed examples, http://nsclient.org/nscp/wiki/CheckDisk/check_drivesize. While looking around it seems I should either be able to do this using 'filter' or 'matching' flags but I'm not sure exactly how.
Using the command below I can get the it to show only C and D drives but it doesn't seem to work for drive names, and I'm not sure how to turn it around so it excludes a drive.
check_nrpe -H 192.168.1.1 -c CheckDriveSize -a FilterType=FIXED matching=.*[CD].* ShowAll=long CheckAll MinWarn=20G MinCrit=10G
According to another post, http://www.nsclient.org/nscp/ticket/651, the command below should work. Although it includes a '!', but even when I create an alias it fails.
Alias
[/settings/external scripts/alias]
alias_test = CheckDriveSize "filter=title not regexp '(?!(Page File))'" $ARG1$ $ARG2$ $ARG3$ $ARG4$ $ARG5$ $ARG6$ $ARG7$
Command
check_nrpe -H 192.168.1.1 -c alias_test -a ShowAll=long CheckAll MinWarn=20G MinCrit=10G
CRITICAL: Could not get free space for: filter filter reason: 3: The system cannot find the path specified.
Any help appreciated.
sreinhardt
-fno-stack-protector
Re: CheckDriveSize Exclude Certain Disk
Post by sreinhardt »
The command you show as working correctly, and the nsclient config\nrpe command that are not working, are quite different. You will need to set the filter, filtertype, match, etc to the same values as your working command to get the same results. Try the following instead:
Alias
alias_test = CheckDriveSize FilterType=FIXED matching=.*[CD].* ShowAll=long CheckAll $ARG1$ $ARG2$ $ARG3$ $ARG4$
NRPE command
check_nrpe -H 192.168.1.1 -c alias_test -a MinWarn=20G MinCrit=10G
Be sure to restart nsclient windows service after modifying the configs and before running the nrpe command.
warnox
Post by warnox »
If I use your 'alias_test' definition I get.
CRITICAL: Could not get free space for: $ARG3$ $ARG3$ reason: 3: The system cannot find the path specified.
But if I remove $ARG3$ and $ARG4$ I get
CRITICAL: C:\: Total: 49.9G - Used: 13.2G (26%) - Free: 36.7G (74%), D:\: Total: 30G - Used: 24.1G (80%) - Free: 5.89G (20%) < critical|'C:\ %'=74%;59;79 'C:\'=13.157G;20;10;0;49.899 'D:\ %'=20%;33;66 'D:\'=24.111G;20;10;0;30
But, this I don't see how this would let me exclude a certain drive from being checked?
Thanks again.
sreinhardt
OH I see, it may take putting it right in front of me some times though. I will have to check into exclusions, I honestly have never done that and do not know if that is a valid option.
Post by Box293 »
Let me help you out Spenser.
You can use the CheckAllOthers argument and specify the drive letter you don't want checked.
Test machine has a C:\ and E:\ fixed drive.
Check showing both drives:
Command:
check_nrpe -H win2008r2-01 -t 30 -c CheckDriveSize ShowAll=long -a MinWarn=20G
Output:
OK: C:\: Total: 59.9G - Used: 12.6G (21%) - Free: 47.3G (79%), E:\: Total: 40G - Used: 91M (0%) - Free: 39.9G (100%)|'C:\ %'=21% 'C:\'=12.58GB 'E:\ %'=0% 'E:\'=90.97MB
Check excluding E:\ drive:
Command:
check_nrpe -H win2008r2-01 -t 30 -c CheckDriveSize ShowAll=long -a MinWarn=20G CheckAllOthers Drive=E:
Output:
OK: C:\: Total: 59.9G - Used: 12.6G (21%) - Free: 47.3G (79%)|'C:\ %'=21% 'C:\'=12.58GB
Check excluding C:\ drive:
Command:
check_nrpe -H win2008r2-01 -t 30 -c CheckDriveSize ShowAll=long -a MinWarn=20G CheckAllOthers Drive=C:
Output:
OK: E:\: Total: 40G - Used: 91M (0%) - Free: 39.9G (100%)|'E:\ %'=0% 'E:\'=90.97MB
Check excluding multiple drives:
Command:
check_nrpe -H win2008r2-01 -t 30 -c CheckDriveSize ShowAll=long -a MinWarn=20G CheckAllOthers Drive=C: Drive=E:
Output:
OK: All drives within bounds.
warnox
Post by warnox »
Ah, I missed that argument. The problem is that the same drive letter is not used for the 'Page File' drive on every server, hence I would like to do it by name. Say, if it contains 'page' or such.
Is it possible to do this with RegEx somehow as per the link on my first page, using 'matching' or 'filter'?
Post by Box293 »
Yeah I'm not really sure about that. If you knew that the combination of drive letters was always Q: P: and X: then you could do Drive=Q: Drive=P: Drive=X: however you run the chance of one of these drive letters being a data drive.
I did some more reading and it looks like NSClient++ 0.4.2 might be able to do it HOWEVER I would steel clear of 0.4.2 as it has lots of weird things going wrong with it. 0.4.1 works OK but it doesn't include the newer options that 0.4.2 has. I would wait for 0.4.3.
It sounds like you need to sit down and set some standards for the drive letter used for page drives.
warnox
Post by warnox »
Alright, looks like I might have to live with a CRITICAL error on the console for a while, unless I separate this server out of the host group (which I rather not do).
Do you have any documentation showing how this would work in 0.4.2 (or 0.4.3)?
Thanks again.
sreinhardt
Not really, unless nsclient provides it on their site. We don't actually develop that agent. Box might chime back in with some useful stuff though!
Post by Box293 »
This is the page that has some information about excluding in 0.4.2:
You could also post a request on the project in github [nscp]. Something like being able to exclude a drive based on the label of a partition.
https://github.com/mickem/nscp
