Good morning.
NagiosXI version: 2014R2.0 - Just updated
Host: Centos 6.6 - running on the metal.
After updating this started happening.
When the server is rebooted I can click on some services..not all...in XI and get:
"Service check is pending....."
It will continue to do this until I manually restart the nagios service:
service nagios restart
This problem DOES NOT exist in Core. The same services are fine there.
Any input would be appreciated.
Service check is pending until nagios service is restarted
Re: Service check is pending until nagios service is restart
Slight correction and a bit more information:
Apparently core does have some effects from the anomaly. I bounced the server this morning and what I described above happened. However, Nagios also couldn't see a couple of remote VMWare hosts I'm monitoring over an ssh tunnel. I could get to the hosts through the tunnel, but Nagios was reporting it couldn't. Once I restarted the nagios service, it was fine.
Any suggestions would be appreciated.
Tbmay,
I'm having this issue for more then a year. Two remote support sessions, but the issue has not been solved. Last session, Andy told me they were working on a fix where the order of service starts would be optimized.
I fear for now you will just have to live with manually restarting Nagios service after a reboot.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
Thank you Willem.
Our suspicion from a few remotes with clients (as we have been unable to reproduce this behavior internally) is that this is due to a race condition between nagios, ndo2db, and mysqld.
