Hi Guys
I checked all other threads.
- I worte config files
- checked for duplicates
- ensured host config is marked as active
But my host stays in Out of Sync, anything else I can check?
Host stays in "OUT OF SYNC" status
Re: Host stays in "OUT OF SYNC" status
Is the CCM spitting out any errors at the bottom of the screen when you apply the config. When you are in the CCM, go to Tools > Write Config Files > Check Config Files
What is the output of running the Check Config Files?
Also, is the date set properly on the server hosting Nagios XI?
Nicholas Scott
