Nagios Core 4.0.8 Notification - Service Alert
esetman
Post by esetman »
Hi experts,
I have a weird problem with Nagios Core 4.0.8 OS CentOS 5.11
Installed it, configured all its working as expected with one exception.
I have a problem with sending Services notifications.
If I set the following values (just like that):
max_check_attempts 1
retry_interval 1
so everything is OK. Notification will be sent
Setting other than 1, 1 for example.:
max_check_attempts 3
retry_interval 3
notification is not sent :(
Annex adding screen configuration.
Interestingly, in the case Hosts Alers notification is sent without problems.
Can you please tell me whats happening. I already google it, but found no anser.
I appreciate you help.
Thank you
my-settings
my-settings
Re: Nagios Core 4.0.8 Notification - Service Alert
Post by Box293 »
So when you say the notification is not sent, has the service entered a hard state?
The reason why your first example works straight away is it will only allow 1 check attempt before going into a hard state.
With your second example, your service must fail three times before it enters a hard state. Example:
1.12pm - Service check fails, retry interval is 3 so next attempt is 1.15pm (check attempt #1) (soft state)
1.15pm - Service check retry fails, retry interval is 3 so next attempt is 1.18pm (check attempt #2) (soft state)
1.18pm - Service check retry fails, max_check_attempts reached (check attempt #3) so alert is sent (hard state)
esetman
Post by esetman »
Thank you for your response :).
Nagios check service 3x. Service entered a hard state.
Host check-host-alive: max_check_attempts 3 retry_interval 3 ==> notification has been send
Servis notification unsent :(
cat /usr/local/nagios/var/nagios.log
[1418107553] PROGRAM_RESTART event encountered, restarting...
[1418107553] Event broker module 'NERD' deinitialized successfully.
[1418107553] Nagios 4.0.8 starting... (PID=30162)
[1418107553] Local time is Tue Dec 09 07:45:53 CET 2014
[1418107553] LOG VERSION: 2.0
[1418107553] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1418107553] qh: core query handler registered
[1418107553] nerd: Channel hostchecks registered successfully
[1418107553] nerd: Channel servicechecks registered successfully
[1418107553] nerd: Channel opathchecks registered successfully
[1418107553] nerd: Fully initialized and ready to rock!
[1418107553] wproc: Successfully registered manager as @wproc with query handler
[1418107553] wproc: Registry request: name=Core Worker 25091;pid=25091
[1418107553] wproc: Registry request: name=Core Worker 25092;pid=25092
[1418107553] wproc: Registry request: name=Core Worker 25093;pid=25093
[1418107553] wproc: Registry request: name=Core Worker 25094;pid=25094
[1418107570] HOST ALERT: ups-u-dedy;DOWN;SOFT;1;CRITICAL - Host Unreachable (192.168.42.1)
[1418107575] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;SOFT;1;connect to address 192.168.42.1 and port 80: No route to host
[1418107706] SERVICE ALERT: ups-u-dedy;PING PO KLENOVCE;CRITICAL;SOFT;1;CRITICAL - Host Unreachable (192.168.42.1)
[1418107709] HOST ALERT: ups-u-dedy;DOWN;SOFT;2;CRITICAL - Host Unreachable (192.168.42.1)
[1418107755] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;SOFT;2;connect to address 192.168.42.1 and port 80: No route to host
[1418107758] HOST ALERT: ups-u-dedy;DOWN;HARD;3;CRITICAL - Host Unreachable (192.168.42.1)
[1418107758] HOST NOTIFICATION: michal-email;ups-u-dedy;DOWN;notify-host-by-email;CRITICAL - Host Unreachable (192.168.42.1)
[1418107758] HOST NOTIFICATION: tatka-email;ups-u-dedy;DOWN;notify-host-by-email;CRITICAL - Host Unreachable (192.168.42.1)
[1418107761] SERVICE ALERT: becolink-prelouc-bod2;PING DO INTERNETU;CRITICAL;SOFT;1;PING CRITICAL - Packet loss = 0%, RTA = 367.52 ms
[1418107761] SERVICE EVENT HANDLER: becolink-prelouc-bod2;PING DO INTERNETU;CRITICAL;SOFT;1;notify-service-by-email
[1418107766] SERVICE ALERT: ups-u-dedy;PING PO KLENOVCE;CRITICAL;SOFT;2;CRITICAL - Host Unreachable (192.168.42.1)
[1418107821] SERVICE ALERT: becolink-prelouc-bod2;PING DO INTERNETU;OK;SOFT;2;PING OK - Packet loss = 0%, RTA = 4.16 ms
[1418107821] SERVICE EVENT HANDLER: becolink-prelouc-bod2;PING DO INTERNETU;OK;SOFT;2;notify-service-by-email
[1418107826] SERVICE ALERT: ups-u-dedy;PING PO KLENOVCE;CRITICAL;HARD;3;CRITICAL - Host Unreachable (192.168.42.1)
[1418107935] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;HARD;3;connect to address 192.168.42.1 and port 80: No route to host
Annex adding new screen
Any idea?
emislivec
Post by emislivec »
Can you post the service definition and the definition for contacts that should be notified? The templates they use will help too.
esetman
Post by esetman »
I attach configuration in Annex. I send something else?
Have you found anything?
thank you
problem-service-notification.zip
(8.78 KiB) Downloaded 256 times
Post by Box293 »
Because you're host has gone down first, service notifications are suppressed.
esetman
Post by esetman »
yes, but already there is not:
[1418192254] SERVICE NOTIFICATION: michal-email;ups-u-dedy;HTTP;CRITICAL;notify-service-by-email;connect to address 192.168.42.1 and port 80: No route to host
[1418192254] SERVICE NOTIFICATION: tatka-email;ups-u-dedy;HTTP;CRITICAL;notify-service-by-email;connect to address 192.168.42.1 and port 80: No route to host
If I set:
retry_interval 1
it's ok: SERVICE NOTIFICATION SEND:
[1418192254] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;HARD;1;connect to address 192.168.42.1 and port 80: No route to host
retry_interval 3
in the log only: (SERVICE NOTIFICATION is missing) :(
esetman
Post by esetman »
Today was a power outage. Thus, everything was down.
It is interesting that two services are set the same as the other non-functional, but the notification was sent.
But it was not sent from all monitored hosts the specific service.
Services - conig name: check_ping service name: PING PO KLENOVCE
has set member hosts: bridge-vesnice-unas,bridge-vesnice-ziegler,gateway-mikrotik-stodola,mikrotik-chalupy-udedy,mikrotik-obec-ziegler,ovislink-ap-unas,ovislink-ap-ziegler,teplomer-u-nas,ups-u-dedy,watch-dog-ziegler
SERVICE ALERT notification has been send from hosts: teplomer-u-nas,bridge-vesnice-unas (only) :(
I do not understand it :(
Do you have any idea?
thank you
esetman
Post by esetman »
Box293 sorry, I missed your reply.
So if check the hosts reached the first state hard, so to suppress the notification of hard state services?
When I disable check hosts:
active_checks_enabled 0
passive_checks_enabled 0
so log:
[1418238418] SERVICE ALERT: ups-u-dedy;PING PO KLENOVCE;CRITICAL;SOFT;1;CRITICAL - Host Unreachable (192.168.42.1)
[1418238461] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;SOFT;1;connect to address 192.168.42.1 and port 80: No route to host
[1418238478] SERVICE ALERT: ups-u-dedy;PING PO KLENOVCE;CRITICAL;SOFT;2;CRITICAL - Host Unreachable (192.168.42.1)
[1418238521] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;SOFT;2;connect to address 192.168.42.1 and port 80: No route to host
[1418238538] SERVICE ALERT: ups-u-dedy;PING PO KLENOVCE;CRITICAL;HARD;3;CRITICAL - Host Unreachable (192.168.42.1)
[1418238581] SERVICE ALERT: ups-u-dedy;HTTP;CRITICAL;HARD;3;connect to address 192.168.42.1 and port 80: No route to host
==> service notification unsent...
abrist
Red Shirt
Post by abrist »
Was the host up during the logs in your last post?
