custom host notification file locations
devildog31415
Post by devildog31415 »
nagiosxi 2014R2.0
CentOS 6.6
I have setup a script for posting to a secured twitter feed.
I don't know:
1) where to put that script
2) where to place the notification command file (does there have to be 2 of them, one for host and one for service notifications?)
3) don't know what else I don't know
The install is the OVF download for 64-bit ESX hosted.
Thank you,
Re: custom host notification file locations
1.) I would place the script under /usr/local/nagios/libexec/plugins or use the web interface to upload it: http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
2.) One command each for hosts and services is the norm, though *technically* you can get away with just one if it doesn't use any macros specific to one or the other.
3.) I had soup today.
Everything should be explained pretty well in that doc, from uploading the script to creating a command for it and attaching as a notification. Except the soup, that's insider knowledge.
