I have updated the Operations Screen Component to version 1.7.2 on my 2 Nagios XI 2014R2.0 servers last week.
The Operations Screen doesn't show any open/unhandled service problems since te update.
Does anyone else have this issue ?
Operations Screen not showing open service problems
Re: Operations Screen not showing open service problems
This has been fixed, however the version it is fixed in has not yet been released, in the meantime, please replace merlin.php with the attached one, in the following directory:
NOTE: Be sure to remove the .txt extension from the file prior to uploading. And verify the following permissions are on the file after uploading:
/usr/local/nagiosxi/html/includes/components/opscreen
-rwxr-x--- 1 nagios nagiosYou do not have the required permissions to view the files attached to this post.
That solved the issue thx !
Great, we'll go ahead and close this thread. Thanks.
