Nagios API check_nagiosxiserver.php load not dividing cores
questrad
Post by questrad »
I have noticed that the Nagios API/check_nagiosxiserver.php load check does not divide by the number of cores installed. Will this be changed in a future release?
Re: Nagios API check_nagiosxiserver.php load not dividing co
My guess is no, because load never takes into account the number of cores, but usage does. Two different terms and each has their pros and cons.
questrad
Post by questrad »
Could I put in a feature/improvement request for this API/Check_nagiosxiserver.php to divide the results by the number of cores or have the ability to add a parameter.
cmerchant
Post by cmerchant »
It might be better if you were to request another measurement (# of processors, # of cores) to add to the check, than to change a metric that indicates the average number of active and running tasks within the measured interval (1, 5, 15 minutes). Besides, if I add additional cores, and my load increases, I would want to properly chart that growth.
A good definition of load is described here:
http://blog.scoutapp.com/articles/2009/ ... d-averages
