I want to try the trial version to present proof of concept for Nagios monitoring system and at the moment I have a problem with configuring Oracle DB connection.
error stands:
CRITICAL - cannot connect to 172.25.xx.xx:1521/db. ORA-12545: Connect failed because target host or object does not exist (DBD ERROR: OCIServerAttach)
Would you be so kind and point me to the right direction?
As well as I would like to know is there any solution/manual to set up monitoring of Oracle Weblogic domain.
Kind regards,
Robert
Oracle DB query error ORA-12545: Connect failed because tar
Re: Oracle DB query error ORA-12545: Connect failed because
What are you using to try to check this oracle database? We need to know what steps you followed to configure this check so we know what plugin you are using, as well as the values you are passing it. Also, if you did not follow it, you do need to follow this guide if using our Oracle DB wizards:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
Thank you for you quick response.
Yes, I have done configuration using the document you mention in your post. I have follow the steps and I end up with error from my previous post.
System is Nagios Demo CentOS run on VMPlayer.
Regards,
Robert
Regards,
Robert
slansing wrote:What are you using to try to check this oracle database? We need to know what steps you followed to configure this check so we know what plugin you are using, as well as the values you are passing it. Also, if you did not follow it, you do need to follow this guide if using our Oracle DB wizards:
I believe it was my fault. I should not use sysdba account to monitoring. After I set up separate monitoring account all works fine.
Thank you and apology for all confusions.
Now if you be able to point me where I can find manual to add monitoring of Oracle Weblogic Server would be great.
Kind regards,
Robert
Kind regards,
Robert
Weblogic:
Cheers!
Note: As this topic is resolved, I am closing the thread. If you have issues with weblogic, please open a new topic.
Cheers!
Yes, please do lock the thread. All is clear.
Regards,
Robert
Regards,
Robert
We'll go ahead and lock this thread. Thanks.
