checkvolsize WMI error - Return code of 255 is out of bounds
thrivikramr
I have a windows server monitoring through WMI. I am trying to monitor volumes created on it, using checkvolsize uisng check_wmi_plus.pl and I am able to get response on command line.
But on XI web interface, it is showing me error 'Return code of 255 is out of bounds', not sure what causing the error and rest of the monitoring is working fine using WMI on this box.
Command line response:
COMMAND: /usr/local/nagios/libexec/check_wmi_plus.pl -H hostname.com -u 'domain/username' -p '*******' -m checkvolsize -a '\?\\Volume\{f4967789-3099-11f3-8768-9abdnhm4m\}' -w '80' -c '95'
OUTPUT: WARNING - [Triggered by _Used%>80] - N:\Log01\ Total=25.00GB, Used=21.58GB (86.3%), Free=3.42GB (13.7%) |'N:\Log01\ Space'=21.58GB; 'N:\Log01\ Utilisation'=86.3%;80;95;
COMMAND: /usr/local/nagios/libexec/check_wmi_plus.pl -H hostname.com -u 'domain/username' -p '*******' -m checkvolsize -a 'N:\Log01\' -w '80' -c '95'
XI web interface response: (Return code of 255 is out of bounds)
Any suggestions how to rectify this? Your help in this regard is much appreciated. Thank you in advance.
ThriVikram
ThriVikram
- Box293
- Too Basu
Re: checkvolsize WMI error - Return code of 255 is out of bo
When you're running the tests on the command line, are you running them as the user nagios?
This is the account the monitoring engine uses.
Also keep in mind that some of these wmi checks create temporary files (in /tmp/ I think). If you tested as the user root then the root user created the file and the nagios user might not have the ability to update it. If this is the case delete the file and then test again as the nagios user.
Does this help?
su nagios
/usr/local/nagios/libexec/check_wmi_plus.pl -H hostname.com -u 'domain/username' -p '*******' -m checkvolsize -a '\?\\Volume\{f4967789-3099-11f3-8768-9abdnhm4m\}' -w '80' -c '95'Also keep in mind that some of these wmi checks create temporary files (in /tmp/ I think). If you tested as the user root then the root user created the file and the nagios user might not have the ability to update it. If this is the case delete the file and then test again as the nagios user.
Does this help?
thrivikramr
I am running this as nagios user and as per the suggestion, checked /tmp for instances. But I didnot find any issues. I have cross checked plugin permissions also for nagios user. Everything seems to be fine.
ThriVikram
ThriVikram
First, are you just running a "test" from the XI cli, or are you saving the check, applying config, and then checking the normally scheduled result?
Next, do you have any illegal/non-standard meta characters in your password? ($, `, ^, !, etc)
thrivikramr
I have added a new service, saved it and applied config to Sync and then checking the normally scheduled result.
Result: (Return code of 255 is out of bounds)
No meta characters involved in my password.
ThriVikram
ThriVikram
Could you post your service check that you created for this so we can review it?
I ran a test on my XI server and I didn't get the error you are seeing.
Thanks.
Thanks.
thrivikramr
Here is my exact service check definition for your reference :- We are using Nagios XI 2014R1.3 hosted on CentOS-6X
XI test Output:
COMMAND: /usr/local/nagios/libexec/check_wmi_plus.pl -H host-name.domain.com -u ''domain/zx_ubcer' -p 'LibWr007' -m checkvolsize -a 'N:\\Log01\\' -w '80' -c '95' -t 60
OUTPUT: WARNING - [Triggered by _Used%>80] - N:\Log01\ Total=25.00GB, Used=22.27GB (89.1%), Free=2.74GB (10.9%) |'N:\Log01\ Space'=22.27GB; 'N:\Log01\ Utilisation'=89.1%;80;95;
host_name host-name.domain.com
service_description PROD05 Log01 Volume Usage
use xiwizard_windowswmi_service
check_command check_xi_service_wmiplus!'domain/zx_ubcer'!'LibWr007'!checkvolsize!-a 'N:\Log01\' -w '80' -c '95'!!!!
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 0
_xiwizard windowswmi
register 1
ThriVikram
ThriVikram
In your settings for the volume name, you are missing a couple of the back slashes
Change the $ARG4$ variable to
-a 'N:\\Log01\\' -w '80' -c '95'Be sure to check out our Knowledgebase for helpful articles and solutions!
naveenreddyv
Issue resolved after changing the $ARG4$ variable.
thank you for the support.
Great! Glad your problem was resolved. We'll go ahead and close this thread. Thanks.
