Offloaded DB and NDO - Now a few questions!
BanditBBS
Post by BanditBBS »
Ok, so I seem to have successfully offloaded my DB and NDO2DB and so far so good. Only a few days will really tell...(please god, vacation starts Friday)
Anyway, I have a few questions that are all mostly simple yes/no.
1.) I should modify the original server and stop ndo2db and mysql from ever starting, correct?
2.) Is there anything else that would ever try and start ndo2db on the original server?(apply config, etc..)
3.) Any work-around for the red exclamation yet?
4.) When upgrading to 2014r2.1 whenever it is released, is that going to try and upgrade ndo2db and/or start it?
5.) If there is an update for ndo2db released with XI ever, do I just copy that over to the new server and run the install and install it over the pre-existing?
6.) reserved for future question :lol:
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
abrist
Red Shirt
Re: Offloaded DB and NDO - Now a few questions!
Post by abrist »
BanditBBS wrote:1.) I should modify the original server and stop ndo2db and mysql from ever starting, correct?
Yes. Kill them with fire. Actually, service. Kill only out of necessity . . .
BanditBBS wrote:2.) Is there anything else that would ever try and start ndo2db on the original server?(apply config, etc..)
Init/Boot? Otherwise, nope. (there will be a db backend button in XI that can as well . . . )
BanditBBS wrote:3.) Any work-around for the red exclamation yet?
Nope. It is in a protected file. I will check the bug report/feature request on that.
BanditBBS wrote:4.) When upgrading to 2014r2.1 whenever it is released, is that going to try and upgrade ndo2db and/or start it?
Yes.
BanditBBS wrote:5.) If there is an update for ndo2db released with XI ever, do I just copy that over to the new server and run the install and install it over the pre-existing?
Essentially. There may also be updated schema (in an .sql file) included as well.
BanditBBS wrote:6.) reserved for future question
No*
BanditBBS
Post by BanditBBS »
Thanks for the replies....feel free to lock this up...
4 and 5 I will open a thread when/if needed.
6 - God I missed Mr No.
cmerchant
Post by cmerchant »
We'll lock this one. Thanks for the questions.
