#!/usr/bin/env php
<?php
$db = "(DESCRIPTION=(ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = host)(PORT = 1521)))(CONNECT_DATA=(SERVICE_NAME=name)))";
$conn = OCILogon ( 'user', 'pass', $db );
if (! $conn) {
exit(2);
exit(0);
command_name check_oracle_login
command_line $USER1$/check_oracle_login
host_name localhost
service_description Check valid login
check_command check_oracle_login
contacts nagiosadmin
contact_groups admins
nagios -v /etc/nagios/nagios.cfgbut when the check is performed I get this error in the front end: (Return code of 126 is out of bounds - plugin may not be executable)
Im running Centos 6.6, and Nagios Core 3.5.1
Any pointers or help appreciated.
