rsyslog can't connect to Nagios Log Server cluster node
stecino
Post by stecino »
Hi all,
I have centos server that I am trying to add to Nagios Log Server
Rsyslog is running, but for some reason it wont connect to Nagios Log Server cluster node
[root@sbur2tl1 ~]# netstat -nap | grep rsyslog
unix 5 [ ] DGRAM 273448 27073/rsyslogd /dev/log
Connectivity is there
[root@sbur2tl1 ~]# telnet xx.xx.1.147 5544
Trying xx.xx.1.147...
Connected to xx.xx.1.147.
Escape character is '^]'.
telnet> quit
This is my nagios log server conf
[root@sbur2tl1 ~]# cat /etc/rsyslog.d/99-nagioslogserver.conf
### Begin forwarding rule for Nagios Log Server NAGIOSLOGSERVER
$WorkDirectory /var/lib/rsyslog # Where spool files will live NAGIOSLOGSERVER
$ActionQueueFileName nlsFwdRule0 # Unique name prefix for spool files NAGIOSLOGSERVER
$ActionQueueMaxDiskSpace 1g # 1GB space limit (use as much as possible) NAGIOSLOGSERVER
$ActionQueueSaveOnShutdown on # Save messages to disk on shutdown NAGIOSLOGSERVER
$ActionQueueType LinkedList # Use asynchronous processing NAGIOSLOGSERVER
$ActionResumeRetryCount -1 # Infinite retries if host is down NAGIOSLOGSERVER
# Remote host is: name/ip:port, e.g. 192.168.0.1:514, port optional NAGIOSLOGSERVER
*.* @@xx.xx.1.147:5544 # NAGIOSLOGSERVER
### End of Nagios Log Server forwarding rule NAGIOSLOGSERVER
I checked and rsyslog is capturing the events
# ### end of the forwarding rule ###
[root@sbur2tl1 ~]# logger 'this is a test'
[root@sbur2tl1 ~]# cat /var/log/messages | grep 'this is a test'
Dec 19 14:55:02 sbur2tl1 root: this is a test
stecino
Re: rsyslog can't connect to Nagios Log Server cluster node
Post by stecino »
Had to explicitly define the rsyslog.conf file. For things to work.
It's weird because on the other ones, it just works. I will have to look at the startup script for rsyslog
Are you still having problems with sending the logs from your Centos server to the Nagios Logserver?
stecino
Post by stecino »
No it got resolved
Thanks for getting back to us. I'll close the ticket.
stecino
Post by stecino »
Actually, I am running into similar issues with Ubuntu. This time it shows that it is connected, but it's not transporting logs, as I don't see logsource being added to the Nagios log server
root@sbur2api01:~# netstat -nap | grep rsyslog
tcp 0 0 10.xx.xx.135:36921 10.xx.x.147:5544 ESTABLISHED 30536/rsyslogd
unix 2 [ ] DGRAM 49501156 30536/rsyslogd /var/spool/postfix/dev/log
unix 2 [ ] DGRAM 49501154 30536/rsyslogd /dev/log
root@sbur2api01:~# logger mytest
root@sbur2api01:~# cat /var/log/syslog | grep mytest
Dec 30 22:00:20 sbur2api01 root: mytest
root@sbur2api01:~# ps -ef | grep rsyslog
syslog 30536 1 0 21:17 ? 00:00:00 rsyslogd -c5 -f /etc/rsyslog.conf
root@sbur2api01:~# cat /etc/rsyslog.d/99-nagioslogserver.conf
$WorkDirectory /var/spool/rsyslog # Where spool files will live NAGIOSLOGSERVER
*.* @@10.xx.x.147:5544 # NAGIOSLOGSERVER
I noticed it's using UTC, vs PST, does it matter?
stecino
Post by stecino »
stecino wrote:Actually, I am running into similar issues with Ubuntu. This time it shows that it is connected, but it's not transporting logs, as I don't see logsource being added to the Nagios log server
I needed to restart logstash on the cluster instances a few times, then logsources appeared
