Design suggestion for sudo
roddergreg
I'd like to recommend using the /etc/sudoers.d directory in place on writing all the nagioslogserver sudo entries directly into /etc/sudoers. Using the /etc/sudoers.d makes managing sudo configurations much easier in my opinion.
sreinhardt
- -fno-stack-protector
Re: Design suggestion for sudo
Which OS did you happen to install on? I know that we keep the usage of original sudoers file for Cent\RHEL 5 varieties that don't necessarily support the config folder. However if you are using Cent\RHEL 6, I would have to check, but I would imagine it to properly separate itself from the main sudoers file. Does this not appear to be the case?
roddergreg
Installed on RHEL 6.5.
roddergreg
We generally try to keep the /etc/sudoers the same across all our servers. This makes sudoers easier to manage using a configuration tools such as puppet or salt. We have many rhel 5 servers using /etc/sudoers.d. To get this working you need sudo >=1.7.2. version with a include variable pointing at /etc/sudoers.d
Remembering that "#" in the sudoers file is not a comment. This is a requirement.
My /etc/sudoers file has all the nagioslogserver entries appended to the end
#includedir /etc/sudoers.dMy /etc/sudoers file has all the nagioslogserver entries appended to the end
User_Alias NAGIOSLOGSERVER=nagios
User_Alias NAGIOSLOGSERVERWEB=apache
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash start
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash stop
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash restart
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash reload
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/logstash status
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch start
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch stop
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch restart
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch reload
NAGIOSLOGSERVER ALL = NOPASSWD:/etc/init.d/elasticsearch status
NAGIOSLOGSERVER ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/change_timezone.sh
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash start
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash stop
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash restart
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash reload
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/logstash status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch start
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch stop
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch restart
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch reload
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/etc/init.d/elasticsearch status
NAGIOSLOGSERVERWEB ALL = NOPASSWD:/usr/local/nagioslogserver/scripts/get_logstash_ports.sh
I think the main issue is that there are some whose repos are not new enough to include 1.7.2/newer. I do believe on the newer distro versions XI does indeed use the .d folder.roddergreg wrote:We have many rhel 5 servers using /etc/sudoers.d. To get this working you need sudo >=1.7.2. version with a include variable pointing at /etc/sudoers.d
roddergreg
Just a suggestion. Take it or leave it
Fair enough. I think we will most definitely be using the .d directories on the newer systems.
