Custom plugins
RIDS_I2MP
Custom plugins
Post by RIDS_I2MP »
Hi team,
Our technical teams have over a period created some custom scripts for infrastructure monitoring (OS+DB+App) and some scripts for Reporting as well in multiple languages and are currently looking at the feasibility of adapting them/build on to create custom plugins for nagios instead on running them as a standalone script.
The scripts are developed in below language:
Shell
Perl
Java
Batch
Power Shell
HTML
Please help us with any artifacts/case studies you have in creating plugins to be executed using nagios from standalone scripts.
Thanks & Regards,
I2MP Team.
Re: Custom plugins
Have them read the following doc to make sure the plugins are Nagios-compliant:
https://nagios-plugins.org/doc/guidelines.html
And then this one to show how to add new plugins to Nagios and make them proper commands:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
RIDS_I2MP
Re: Custom plugins
Post by RIDS_I2MP »
Thanks for the reply.
Are the languages stated in the above post compatible with Nagios?
Thanks & Regards,
I2MP Team.
Re: Custom plugins
The short answer is yes, however the items that run on Windows would need to be called through an agent such as NSClient++
Re: Custom plugins
Pretty much any language can be used to write plugins for Nagios, as long as it can provide output to stdout.
HTML, however, is not a programming language and cannot be used to write plugins.
