In the changelog it says this: "Added ability for Alert Histogram report to allow selecting services and shows all host alerts including services or host only -JO"
I don't see any option to select services and hosts. And the issue was if you select a hostgroup is only showed the host alerts and not the services in that hostgroup as well. Is that update worded poorly or is this still the case?
2014r2.1 Question about Histogram
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: 2014r2.1 Question about Histogram
Filtering by services seems to work fine for me in the Alert Histogram...
Perhaps a caching issue...?
Ahh, no, just not what I was hoping for, lol. That option only comes up when limiting to a specific host. I was needing it when selecting hostgroups.lmiltchev wrote:Filtering by services seems to work fine for me in the Alert Histogram... Perhaps a caching issue...?
Please reopen http://tracker.nagios.com/view.php?id=624 as the functionality doesn't exist that the feature request asked for(Although I bet it can be added easily now
edit: I found the reopen button
Oh, I see. Well, it's up to the devs now.
Is it OK if I lock this topic?
Yep, lock it up!
