check_logfile log rotation
tgfde
Post by tgfde »
I'm currently using the 'check_logfiles' plugin but having a hard figuring the rotation format for a weblogic server. The rotation format is shown below:
ms1.log -> ms1.log.00001 -> ms1.log.00002
Has anyone figured it out or know it? Thanks in advanced.
FYI. I sent an email to the third party for this plugin, and waiting for a response, but just wanted tot see if anyone has done this.
tgfde
sreinhardt
-fno-stack-protector
Re: check_logfile log rotation
Post by sreinhardt »
Do you have a link to the plugin available?
tgfde
Post by tgfde »
sreinhardt
Well according to their plugin, it would be something like "msg1.logmsg1.log.00001msg1.log.00002". It's pretty hard to tell from their documentation what correct usage would be. However, if you only ever need to look at the first log file, using no pattern would be just fine as well.
tgfde
Post by tgfde »
Thank you for the quick response. I will try this if the one provided by lausser from ConSol Labs, shown below.
logfile => ‘ms1.log’,
rotation => ‘ms1\.log\.\d{5}’,
sreinhardt
That should do it, provided it is looking for an actual regex, and not what they were showing through documentation.
