Nagios Monitoring ERROR/BUG
rmuhammadali
Post by rmuhammadali »
Dear All,
I found an error while running nagios. The problem arise when i use check_nrpe!check_swap and the output is "(Return code of 255 is out of bounds)" giving status OK. On the other side when i use check_ssh, the output is "connect to address xxx.xxx.xxx.xxx and port 22: No route to host".
Assuming that the remote host is down in this situation. Following are two examples of my nagios service configuration.
host_name client2
service_description Swap Usage
check_command check_nrpe!check_swap
host_name client2
service_description SSH Monitoring
check_command check_ssh
Please help me, how to manage this isue. Snapshot attached.
Regards
RMA
Re: Nagios Monitoring ERROR/BUG
Post by Box293 »
Can you post the command definitions for check_nrpe and check_ssh
rmuhammadali
Dear,
Following are my check_nrpe and check_ssh command definations.
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
command_name check_ssh
command_line $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
Regards
RMA
Post by Box293 »
rmuhammadali wrote:define command{
host_name client2
With the host you are trying to test, in your host definition file is this a DNS name or an IP address?
From the command line of your nagios host can you ping the DNS name or an IP address?
rmuhammadali wrote:define service{
host_name client2
On your remote host you will have the check_swap command defined in the file /usr/local/nagios/etc/nrpe.cfg OR in the file /usr/local/nagios/etc/nrpe/common.cfg
Is this the case, does an entry for check_swap exist?
Also, have you configured the only_from entry in/etc/xinetd.d/nrpe ?
rmuhammadali
/etc/xinetd.d/nrpe Configuration
only from = nagiosserverip
/usr/local/nagios/etc/nrpe.cfg Configuration
command[check_swap]=/usr/local/nagios/libexec/check_swap -w 40% -c 20%
Actually i have down the nrpe client machine to check added monitors.
Regards
RMA
Can you show the permissions of the check_swap file on the remote system
ls -l /usr/local/nagios/libexec/check_swap
rmuhammadali
Dear,
As i mentioned earlier that assume the remote machine is down, in that case there is nothing concerns with check_swap permissions on remote host. Anyhow the permissions are
ls -al /usr/local/nagios/libexec/check_swap
-rwxr-xr-x. 1 root root 141169 Dec 20 11:48 /usr/local/nagios/libexec/check_swap
The question is how to manage "(Return code of 255 is out of bounds)" this error when remote host is down.
Regards
RMA
abrist
Red Shirt
Post by abrist »
If the host is down, nrpe should time out, not return 255.
rmuhammadali
Dear,
thats the situation, it show
Current Status: OK
Status Information: (Return code of 255 is out of bounds)
Rather then time out or some other status like warning or critical.
Regards
RMA
rmuhammadali
Dear,
After keen observation, i found out the following statistics
1) When System is up and running
[root@nagios myconf]# /usr/local/nagios/libexec/check_nrpe -H 192.168.2.7 -c check_swap
SWAP OK - 100% free (999 MB out of 999 MB) |swap=999MB;399;199;0;999
nrpe SystemUP 1.jpg (11.02 KiB) Viewed 4931 times
2) When System is down manually
First Result
CHECK_NRPE: Socket timeout after 10 seconds.
Then on the Second check
connect to address 192.168.2.7 port 5666: No route to host
connect to host 192.168.2.7 port 5666: No route to host
nrpe SystemDOWN 1.jpg (10.11 KiB) Viewed 4931 times
Regards
RMA
