How to add DDos Monitoring Service
I've added service and command in nagios but still getting error while starting nagios service.
host_name XYZ
service_description DDOS
check_command check_ddos
command_name check_ddos
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c check_ddos -w $ARG1$ -c $ARG2$
host_name XYZ
Re: How to add DDos Monitoring Service
What error are you getting? It will be hard to diagnose without seeing that.
Here's the error "Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration."
Can you post the preceding lines to the above error? There should be a more verbose error earlier in the verification output.
i'm getting error while restart nagios service.
#service nagios restart
I have placed "check_ddos.pl" script on remote host.
lets verify the config, e.g.
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgRe: How to add DDos Monitoring Service
/usr/local/nagios/bin/nagios -v /etc/nagios/nagios.cfg
-bash: /usr/local/nagios/bin/nagios: No such file or directory
There's no nagios in this path: /usr/local/nagios/bin/nagios
That was an example, you would have to change the path to the directory you nagios bin is located, same goes for the cfg file, you would have to use the path you have on YOUR server.
Here's the outcome.
Error: Could not find any host matching 'XYZ' (config file '/etc/nagios/servers/webs-services.cfg', starting on line 79)
Error: Could not expand hostgroups and/or hosts specified in service (config file '/etc/nagios/servers/webs-services.cfg', starting on line 79)
79 line starts from define service.
host_name XYZ
host_name XYZ
