How to add Task scheduler in Nagios
HAL
Post by HAL »
Hi Team,
We need to add task scheduler in nagios Monitoring which run in specific time .
So we need to check whether scheduler is running in specific time.
IF it possible to added in nagios .Kindly provide us solution for this
Thanks and Regards,
Hoegh
Re: How to add Task scheduler in Nagios
Could you give us more details on what type of schedule you want to monitor and the system that the task runs on?
HAL
Post by HAL »
ITS 2003 server and there are 3 task schedular which run 3 times in day . I want to check whether that schedular in running on server at sepecific interval
I would recommend looking for a suitable plugins on the Nagios Exchange. Here's one link I found:
http://exchange.nagios.org/directory/Pl ... ks/details
I am not sure if this is going to do the job for you, but if you had a script that you could run locally on the Windows machine, you could use with with NPCA or NSClient++ in Nagios XI.
