Service group status
I have a service group with 5 service checks in it. i was wondering if there is a way to have a status on the group to warn if there are 2 out of the 5 services down and critical if 4 out of the 5 checks are down?
Re: Service group status
You might need to make your own custom check that checks multiple hosts in the same check and determine the number avail.
Look at this post: http://support.nagios.com/forum/viewtop ... 442#p87904
or you might look at BPI that was also mentioned in that post:
http://exchange.nagios.org/directory/Ad ... 29/details
