When I select Nagvis from the NagiosXI menu I get
Not Found
The requested URL /nagvis/ was not found on this server.The nagvis conf file is still missing - /etc/httpd/conf.d/nagvis
I can always copy this from one of my other Nagios servers - just thought I'd let you know in case the installation script can be improved?
Btw - this is one of the NagiosXI 2014R1.9 VMs I downloaded from your site last year. - Just upgraded it to 2014R2.3 - still no Nagvis.
# cd /usr/local/nagiosxi/html/includes/components/nagvis/
# chmod +x install.sh
# ./install.sh
Not using downloaded repomd.xml because it is older than what we have:
Current : Fri Jul 11 09:46:59 2014
Downloaded: Wed Jul 25 09:43:04 2012
Loaded plugins: fastestmirror
Ignored option -q, -v, -d or -e (probably due to merging: -yq != -y -q)
Setting up Install Process
Loading mirror speeds from cached hostfile
* base: mirror.internode.on.net
* epel: mirror.optus.net
* extras: mirror.internode.on.net
* rpmforge: mirror.fairway.ne.jp
* updates: mirror.internode.on.net
No package 2.26.0 available.
Package graphviz-gd-2.26.0-10.el6.x86_64 already installed and latest version
Package php-gd-5.3.3-40.el6_6.x86_64 already installed and latest version
Package php-mbstring-5.3.3-40.el6_6.x86_64 already installed and latest version
Package php-mysql-5.3.3-40.el6_6.x86_64 already installed and latest version
Package php-pdo-5.3.3-40.el6_6.x86_64 already installed and latest version
Package php-xml-5.3.3-40.el6_6.x86_64 already installed and latest version
Package php-common-5.3.3-40.el6_6.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package graphviz.x86_64 0:2.26.0-10.el6 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
graphviz x86_64 2.26.0-10.el6 base 1.0 M
Transaction Summary
Install 1 Package(s)
Total download size: 1.0 M
Installed size: 2.7 M
Downloading Packages:
graphviz-2.26.0-10.el6.x86_64.rpm | 1.0 MB 00:02
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Warning: RPMDB altered outside of yum.
** Found 8 pre-existing rpmdb problem(s), 'yum check' output follows:
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of /usr/bin/dot
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of graphviz = ('0', '2.26.0', '10.el6')
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of libcdt.so.4()(64bit)
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of libgraph.so.4()(64bit)
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of libgvc.so.5()(64bit)
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of libpathplan.so.4()(64bit)
graphviz-gd-2.26.0-10.el6.x86_64 has missing requires of libxdot.so.4()(64bit)
nagiosxi-deps-2014r1.5-1.noarch has missing requires of graphviz
Installing : graphviz-2.26.0-10.el6.x86_64 1/1
Verifying : graphviz-2.26.0-10.el6.x86_64 1/1
Installed:
Complete!
# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
