multy-tenancy problem with contactgroups
morabanc
Post by morabanc »
We're migrating a nagios core to a new nagios XI, and we have a problem with multi-tenancy. Contacts that belongs to an specific contactgroup should see specific hosts and services, but users cant' see anything. But if I add a contact to the hosts instead of the complete contactgroup then this contact can see the host. It seems multi-tenancy is working using contacts, but not with contactgroups.
the server is a RedHat Linux with Nagios XI 2014R2.3
Regards
Re: multy-tenancy problem with contactgroups
I need to ask this first - have you verified that you added the desired contacts to the contactgroup? Can the user see hosts/services in Nagios Core? Do you have any mysql errors in the mysqld.log?
tail -20 /var/log/mysqld.log
It is possible that you are missing the "importance" columns in the nagios_hosts, nagios_services, and nagios_contacts tables in the nagios database... Run the following command and show us the output:
echo "use nagios;desc nagios_hosts;desc nagios_services;desc nagios_contacts;" | mysql -t -pnagiosxi
morabanc
Post by morabanc »
Yes, the contacts are in the contact groups. And it seems mysql is working correctly.
You're right about the "importance" column. When I run the command this column is not appearing, curiously, we're using sql-front to manage the DB, and I can see the column in the object browser view. tables nagios_contacts and nagios_hosts are empty.
I attach the result of the command.
Well, hopefully this would be an easy fix. Run the following commands to add the missing columnts:
mysql -pnagiosxi
use nagios;
alter table nagios_services add column importance int not null default 0;
alter table nagios_hosts add column importance int not null default 0;
alter table nagios_contacts add column minimum_importance int not null default 0;
\q
service mysqld restart
Let me know if this fixed your issue. Thanks!
morabanc
Post by morabanc »
Hello
It worked! the problem was with nagios_contacts table, field minimum_importance not existed.
Thanks for your support
cmerchant
Post by cmerchant »
Great! We'll go ahead and close this thread. Thank you.
