Integrate Nagios to Netflow
lafargeuser
Post by lafargeuser »
How to Integrate Nagios to Netflow ?
Is Netflow is separate server which will integrate with Nagios or Netflow is plugin which can be installed on Nagios XI server
Re: Integrate Nagios to Netflow
Netflow is a protocol, not a specific product. Netflow data is sent out, usually by a router or switch, and contains data regarding the traffic on a port or device. Other applications can then interpret that Netflow data and use it to draw graphs, analyze trends, and do lots of other cool things with it.
We have a product called Nagios Network Analyzer that was built specifically to work with Netflow data in the ways I have described.
Check it out here: http://www.nagios.com/products/nagios-network-analyzer
You can download a free 60-day trial if you want to try it out.
