Arguments not allowed
JohnFLi
Post by JohnFLi »
http://exchange.nagios.org/directory/Pl ... s)/details
I am trying to get the above plugin to work.
As far as I can tell, I have everything set correctly.
in the nsclient.log, it reads
1:17: e:..\..\..\..\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:242: Arguments not allowed in CheckExternalScripts set /settings/external scripts/allow arguments=true
When I try to run the command manually, it says
[root@g1vpnag01 libexec]# ./check_nrpe -t 10 -H g1pprend01 -c check_users -a 2 3 "john"
On the Nagios web display, it show
(No output on stdout) stderr: execvp(command_line, ...) failed. errno is 2: No such file or directory
here is my nsclient.ini
# If you want to fill this file with all avalible options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 1
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 1
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 1
; Check NSCP - Checkes the state of the agent
CheckNSCP = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; CheckWMI - CheckWMI can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckWMI = 1
; NRPE server - A simple server that listens for incoming NRPE connection and handles them.
NRPEServer = 1
; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility.
NSClientServer = 1
NSCAClient = 1
NSClientServer = 1
[/settings/NRPE/server]
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = True
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = True
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = g1vpnag01
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = checkCPU warn=80 crit=90 time=5m time=1m time=30s
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = checkProcState "$ARG1$=started"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = checkProcState "$ARG1$=stopped"
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = checkServiceState CheckAll
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = checkUpTime MinWarn=1d MinWarn=1h
; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates
alias_updates = check_updates -warning 0 -critical 0
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
; default - Alias for default. To configure this item add a section called: /settings/external scripts/alias/default
default =
check_users=scripts\perl\check_users.exe "$ARG1$" "$ARG2$" "$ARG3$"
I do have check_users.exe in the C:\Program Files\NSClient++\scripts\perl directory
My NSClinet version is 0.4.1.105
Any ideas?
Everybody is somebody else’s weirdo
Re: Arguments not allowed
Post by Box293 »
Your setting is residing in the wrong key:
This should be:
[/settings/external scripts]
Here's a command line way of setting the options:
nscp settings --activate-module CheckExternalScripts --add-defaults
nscp settings --path "/settings/external scripts" --key "allow arguments" --set true
nscp settings --path "/settings/external scripts" --key "allow nasty characters" --set true
JohnFLi
Post by JohnFLi »
Ok, it now reads
[/settings/external scripts/]
Now the error I am getting is
No handler for command: check_users
and in the nsclient.log
2015-01-12 15:59:41: e:..\..\..\nscp\service\NSClient++.cpp:563: Exception raised: 'Could not load library: 126: The specified module could not be found.
: C:\Program Files\NSClient++\\modules\True.dll' in module: True
2015-01-12 15:59:45: e:..\..\..\nscp\service\NSClient++.cpp:980: No handler for command: check_users avalible commands: commands {, check_cpu, check_eventlog, check_memory, check_nscp, check_ok, check_pdh, check_process, check_registry, check_service, check_uptime, checkalwayscritical, checkalwaysok, checkalwayswarning, checkcounter, checkcpu, checkcritical, checkdrivesize, checkeventlog, checkfile2, checkfiles, checkfilesize, checkmem, checkmultiple, checkok, checkprocstate, checkservicestate, checksingleregentry, checkuptime, checkversion, checkwarning, checkwmi, checkwmivalue, listcounterinstances, nsca_exec, nsca_forward, nsca_help, nsca_query, nsca_submit}, plugins {, 0, 1, 2, 3, 4, 5, 7}
2015-01-12 15:59:45: e:..\..\..\..\nscp\include\nscapi\nscapi_core_wrapper.cpp:181: No handler for command 'check_users'.
Post by Box293 »
Can you please post your updated nsclient.ini
JohnFLi
Post by JohnFLi »
here you go
[/modules]
CheckDisk = 1
CheckEventLog = 1
CheckExternalScripts = True
CheckHelpers = 1
CheckNSCP = 1
CheckSystem = 1
CheckWMI = 1
NRPEServer = 1
NSClientServer = 1
NSCAClient = 1
NSClientServer = 1
[/settings/default]
default =
Post by Box293 »
A couple of things
You had:
But it needs to be:
CheckExternalScripts = enabled
The settings and the scripts need to be in separate paths
Also, you had a trailing forward slash after the word scripts which would have caused the allow arguments setting to be under the incorrect path
Bad:
Good:
Working config should resemble this:
[/modules]
CheckDisk = 1
CheckEventLog = 1
CheckHelpers = 1
CheckNSCP = 1
CheckSystem = 1
CheckWMI = 1
NRPEServer = 1
NSClientServer = 1
NSCAClient = 1
NSClientServer = 1
[/settings/default]
default =
JohnFLi
Post by JohnFLi »
Great, thank you.
That fixed that error.
Now the script itself isn't working
[root@g1vpnag01 libexec]# ./check_nrpe -t 10 -H g1pprend01 -c check_users -a 2 3 "$HOSTALLOWEDUSERS$"
'query' is not recognized as an internal or external command,
operable program or batch file.
OK: 0 users logged in
Active Sessions:
Wish I knew about perl.
JohnFLi
Post by JohnFLi »
I contacted the creater of the script.
He had a fix, and it appears to be working now.
Thank you all
Post by slansing »
Oh excellent, do you know if he is going to share it on his exchange page?
JohnFLi
Post by JohnFLi »
He said he was going to.
Also, sadly enough, once I got it working, it doesn't do what I need. lol but it almost does
it works great if a user is activly remoted into a machine. But if they close the RDP session (not logging out), his check will show the person is no longer there, when in fact they still are.
Back to the searching board for me.
