I upgraded recently from 3.5 to 4.0.8.
In 3.5, I made some tests to check the behavior of LONGSERVICEOUTPUT: I formated the output of my plugin as explained in the documentation, and expected things happened.
Now, with 4.0.8 it seems to me that there is a new bug in the decoding of plugin output...
I wrote a very simple plugin which return exactly the output showed in the documentation: http://nagios.sourceforge.net/docs/nagi ... inapi.html ("DISK OK - free...").
And when I look at the GUI, the example of the documentation is not decoded as explained by the documentation.
It is decoded in the following way:
Status Information: DISK OK - free space: / 3326 MB (56%):
Performance Data: /=2643MB;5948;5958;0;5968 / 15272 MB (77%); /boot 68 MB (69%); /home 69357 MB (27%); /var/log 819 MB (84%); | /boot=68MB;88;93;0;98 /home=69357MB;253404;253409;0;253414 /var/log=818MB;970;975;0;980
Changes in version 4.0.8 for LONGSERVICEOUTPUT?
Re: Changes in version 4.0.8 for LONGSERVICEOUTPUT?
Could you post your plugin and how the check command is defined so we can review it?
To answer you, I tried to write a very simple plugin (simplier than my plugin having problems). And I associated this plugin to a brand new service.
And it works as expected and as the documentation says.
So the problem comes from elsewhere...
#! /bin/bash
echo 'DISK OK - free space: / 3326 MB (56%); | /=2643MB;5948;5958;0;5968
/ 15272 MB (77%);
/boot 68 MB (69%);
/var/log=818MB;970;975;0;980'
exit 0
So it is working after all?
Are you using mod_gearman? (there was a newline bug with core4 and gearman)
My fault!
For convenience, I wrapped my own plugins with a shell script that makes various things related to my project.
And in that shell script, I wrote
echo $called_nagios_plugin_output
instead of
echo "$called_nagios_plugin_output"
Without the quotes, the shell script eats my end of lines.
Problem is now fixed and thanks for your interaction.
instead of
