New Check Question
mbowden
New Check Question
Post by mbowden »
I created a small batch script to check for the existence of one of 2 services on a windows machine. The service that I created uses check_nrpe. I have an issue where the script works fine on both platforms locally form the cmd line, so the script is good.
However from Nagios the command works perfectly on a 32 bit windows box and fails on a 64 bit box saying "No handler for command: win_check_puppet.bat"
I have put the script "win_check_Puppet.bat" in the scripts folder on both platforms.
Both Clients have identical NSC.ini files, The pertinent sections are below (I think)
; Script to check external scripts and/or internal aliases.
CheckExternalScripts.dll
and
[External Scripts]
win_check_Puppet.bat=scripts\win_check_Puppet.bat
From what I have read it seems possible that the nsclient.ini may need to be edited as well? If so can you help with syntax for that file. I have tried adding this and restarting the service with no luck.
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; win_check_Puppet.bat - Alias for win_check_Puppet.bat. To configure this item add a section called: /settings/external scripts/scripts/win_check_Puppet.bat
win_check_Puppet.bat = scripts\win_check_Puppet.bat
Thank You
Mike
mbowden
Re: New Check Question
Post by mbowden »
This line added to the nsclient.ini resolved the issue
win_check_Puppet = scripts\\win_check_Puppet.bat
Post by slansing »
I was actually just about to reply back to you with an external scripts line, glad you got it worked out!
