PHP errors
ssa_nagios
PHP errors
Post by ssa_nagios »
Looking in /var/log/httpd/error_log I'm seeing a lot of php errors. When I go to look at the files I'm unable to view the php scripts I can view the source code. Below are the errors that I'm seeing in the logs...
[Fri Jan 16 06:31:39 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: sa in /usr/local/nagiosxi/html/config/configobject.php on line 1026, referer: http://nsc-prd-nagiosxi-006/nagiosxi/in ... ba.ssa.gov
[Fri Jan 16 06:48:06 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home_id in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 283, referer: http://nsc-prd-nagiosxi-006/nagiosxi/in ... -index.php
[Fri Jan 16 06:48:06 2015] [error] [client 10.27.178.18] PHP Warning: array_multisort(): Argument #1 is expected to be an array or a sort flag in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 285, referer: http://nsc-prd-nagiosxi-006/nagiosxi/in ... -index.php
[Fri Jan 16 06:48:06 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 289, referer: http://nsc-prd-nagiosxi-006/nagiosxi/in ... -index.php
[Fri Jan 16 06:48:39 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home_id in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 283
[Fri Jan 16 06:48:39 2015] [error] [client 10.27.178.18] PHP Warning: array_multisort(): Argument #1 is expected to be an array or a sort flag in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 285
[Fri Jan 16 06:48:39 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 289
[Fri Jan 16 08:15:44 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home_id in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 283
[Fri Jan 16 08:15:44 2015] [error] [client 10.27.178.18] PHP Warning: array_multisort(): Argument #1 is expected to be an array or a sort flag in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 285
[Fri Jan 16 08:15:44 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 289
[Fri Jan 16 08:16:12 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home_id in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 283
[Fri Jan 16 08:16:12 2015] [error] [client 10.27.178.18] PHP Warning: array_multisort(): Argument #1 is expected to be an array or a sort flag in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 285
[Fri Jan 16 08:16:12 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: home in /usr/local/nagiosxi/html/includes/utils-dashboards.inc.php on line 289
[Fri Jan 16 08:16:49 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: search in /usr/local/nagiosxi/html/admin/users.php on line 154, referer: http://nsc-prd-nagiosxi-006/nagiosxi/admin/
[Fri Jan 16 08:26:55 2015] [error] [client 10.27.179.55] PHP Notice: Undefined variable: display_error in /usr/local/nagiosxi/html/login.php on line 805
[Fri Jan 16 08:27:15 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: theme in /usr/local/nagiosxi/html/admin/users.php on line 1123, referer: http://nsc-prd-nagiosxi-006/nagiosxi/ad ... er_id[]=56
[Fri Jan 16 08:30:13 2015] [error] [client 10.27.178.18] PHP Notice: Undefined variable: display_error in /usr/local/nagiosxi/html/login.php on line 805
[Fri Jan 16 08:34:14 2015] [error] [client 10.27.179.55] File does not exist: /var/www/html/favicon.ico
[Fri Jan 16 08:34:15 2015] [error] [client 10.27.179.55] File does not exist: /var/www/html/favicon.ico
[Fri Jan 16 08:43:52 2015] [error] [client 10.27.179.55] PHP Notice: Undefined variable: c in /usr/local/nagiosxi/html/includes/components/latestalerts/latestalerts.inc.php on line 522, referer: http://nsc-prd-nagiosxi-006/nagiosxi/in ... ton=Update
Here is an example of the php files (login.php)
[root@nsc-prd-nagiosxi-006 httpd]# more /usr/local/nagiosxi/html/login.php
<?php @"SourceGuardian"; //v9.0 ?><?php // Copyright (c) 2008-2014 Nagios Enterprises, LLC. All rights reserved. ?><?php
if(!function_exists('sg_load')){$__v=phpversion();$__x=explode('.',$__v);$__v2=$__x[0].'.'.(int)$__x[1];$__u=strtolower(substr(php_uname(),0,3));$__ts=(@
constant('PHP_ZTS') || @constant('ZEND_THREAD_SAFE')?'ts':'');$__f=$__f0='ixed.'.$__v2.$__ts.'.'.$__u;$__ff=$__ff0='ixed.'.$__v2.'.'.(int)$__x[2].$__ts.'
.'.$__u;$__ed=@ini_get('extension_dir');$__e=$__e0=@realpath($__ed);$__dl=function_exists('dl') && function_exists('file_exists') && @ini_get('enable_dl'
) && !@ini_get('safe_mode');if($__dl && $__e && version_compare($__v,'5.2.5','<') && function_exists('getcwd') && function_exists('dirname')){$__d=$__d0=
getcwd();if(@$__d[1]==':') {$__d=str_replace('\\','/',substr($__d,2));$__e=str_replace('\\','/',substr($__e,2));}$__e.=($__h=str_repeat('/..',substr_coun
t($__e,'/')));$__f='/ixed/'.$__f0;$__ff='/ixed/'.$__ff0;while(!file_exists($__e.$__d.$__ff) && !file_exists($__e.$__d.$__f) && strlen($__d)>1){$__d=dirna
me($__d);}if(file_exists($__e.$__d.$__ff)) dl($__h.$__d.$__ff); else if(file_exists($__e.$__d.$__f)) dl($__h.$__d.$__f);}if(!function_exists('sg_load') &
& $__dl && $__e0){if(file_exists($__e0.'/'.$__ff0)) dl($__ff0); else if(file_exists($__e0.'/'.$__f0)) dl($__f0);}if(!function_exists('sg_load')){$__ixedu
rl='http://www.sourceguardian.com/loaders/d ... '&os_s='.u
rlencode(php_uname('s')).'&os_r='.urlencode(php_uname('r')).'&os_m='.urlencode(php_uname('m'));$__sapi=php_sapi_name();if(!$__e0) $__e0=$__ed;if(function
_exists('php_ini_loaded_file')) $__ini=php_ini_loaded_file(); else $__ini='php.ini';if((substr($__sapi,0,3)=='cgi')||($__sapi=='cli')||($__sapi=='embed')
){$__msg="\nPHP script '".__FILE__."' is protected by SourceGuardian and requires a SourceGuardian loader '".$__f0."' to be installed.\n\n1) Download the
required loader '".$__f0."' from the SourceGuardian site: ".$__ixedurl."\n2) Install the loader to ";if(isset($__d0)){$__msg.=$__d0.DIRECTORY_SEPARATOR.
'ixed';}else{$__msg.=$__e0;if(!$__dl){$__msg.="\n3) Edit ".$__ini." and add 'extension=".$__f0."' directive";}}$__msg.="\n\n";}else{$__msg="<html><body>P
HP script '".__FILE__."' is protected by <a href=\"http://www.sourceguardian.com/\">SourceGuardian</a> and requires a SourceGuardian loader '".$__f0."' t
o be installed.<br><br>1) <a href=\"".$__ixedurl."\" target=\"_blank\">Click here</a> to download the required '".$__f0."' loader from the SourceGuardian
site<br>2) Install the loader to ";if(isset($__d0)){$__msg.=$__d0.DIRECTORY_SEPARATOR.'ixed';}else{$__msg.=$__e0;if(!$__dl){$__msg.="<br>3) Edit ".$__in
i." and add 'extension=".$__f0."' directive<br>4) Restart the web server";}}$msg.="</body></html>";} die($__msg);exit();}}return sg_load('100590ECE17C
5C2CAAQAAAASAAAABHAAAACABAAAAAAAAAD/vrcIMAn1sS1GR3GMRJPP9Ka9tVymc49qszUM5gRGFQnVHYvWcHgOVxWBJjEBBuPHjtfqVba/mgnAtWtOdZJGnKE7pXL1DANV4Q/6CCPhw/H9V70Kz0qOo
cnMB5Hve/s84ITJCSC9xJ2HiWTVdpjgEAUAAAAwdAAA0/avjKBTv9oG6ys/TxNiOwCMm4TOQisb+V4j5kAXlXgNIQl+9IfvQM9EJ4pjvzKk1nYYIN/281SxqeIn+fF16L56eLQN+yKUaHDUZuIMTULdLL
jDXfxDaxVN0S/gWnPcKMRWI/lpG5za9MimMnSUiTKNj/g7+AMqEGF8IgLihxFhCoRPtvEG5C0StrrKgfhI+vPW0PSRgZo8Wnile3VERDD0ohF9twL3l1Pc+v+DtzoyA/dyxHImArZPzP+zGrtfbuz5Gvn
eiUcbAl8US9tbc08VNnoEoFfdI+4vtTpamBSizwfI2kYDHp4y4Qc+ltijdyK2V2oMnsfyHTvpjSJBARMmfsdKnGfDBavwHG0IiM3PAtfZCOoKLuAp15b13WEQVHy8Hk3KynjD1HWEQOpwyhfhghioi8MO
RAEM1g1wJNnXUTKe+AIwpGlpIDIAyJnVQ3X8tJ52Po6yqKaMhBQbtWRw8NcELGGS/KKWXoOsHOeTMEp6fBulHXtIcX5LvRg/jODRGtLp67y8dno+y29+KANOhD6UNB/l47honKT0jZtgvKHjw/aVCFaxI
e53mKNVuWNhKr7qRg2W1dykcBvNgHTUNLssSqU5JNttsNrvM1QPm0CNl27QOLRuZ+P9nmzApSIHSg37rJe6saJjNw1V99nxqRmcmoM3vWxnwQuglGB8qBHn9+ModFFtWYP1vJK62Ej7kVIAbZ75tnKVtV
HswwZEfh/jqddh9VTrwqKgdcOJUyMdNXhj6ZV2JJZXMjpRhOyiKmwiPTak50rNcbxmvdzUT263D05yKsMgPykEmbKZ6S51vOcgf++MBGNaMZvIiIyNlagPOzvebfEg48JlZv8I14qabKjMTz76RDwfXC9
B3mXgKU1+ZQ/hA0on1kaeYed350gB7j+4xkSmKUaX77Nw9qh0uDPPosqcDUBq2C/yeYrQXumAe6KrP/oqqJ+XYQ9J4i4pc8T+5chTRHApZg3qUBVkpJR20/NIPYPVOptE3wUbdiXbtcIDh3ovlqxqZoAb
zhje9BZ9iUx67GYCszB38hUT11bbjgaagwgvngObQ4Lvj8lE1DI1CyLFDDui8fuCkelJQpM2rrMZzTIOKesp3T+WHNiQT0bZyTUsL2HFyAvVnfqxvvTuPB6EbcmfZFI2fuXsicGsa6Fy06nssncSTFBZi
N+6piOqwOypU8x3b76MUNKyAUXQWK9h9l3stK6IQ3a0YneUdmxdcToOZD3ny5sBy45B9DPiUr9xy3twe9Ezp1wwkSFvUDJHqTSaDkvc6IZ9YMW0YU0A8rQudoJQrB/yg5ui5Mot9HObezeqs/rGyd+TX/
dCOLwJ2Or7K/KrvIw1iijqdO0cBsBi4AgW0hJ9wYgQLPnJAY1tDJfM2g+GmckkKjwFkAH6arLCDG2lXSoL5TGDxMass1N5tg8qPOYWuJUOl8HVElQcQ2Rct/m+XfT8UqC0+nzIJ631cHvhIGKPL2JPuHy
K8EMPZUYlcr6mBfnjepinhMMGAZrbRBoECRcrzhhpEy6moVef/DXLqFQrkYAtcCc2f/HUjQnKMq1mcGgPabd/CeAwf65JaeYjPtHY2mhhqGZSFxj8PJoNWj1qmwoGxABaPYT31duGYLMmx2iocBa5LKB6
/j6uhl+WfZrdKHpaS3PPd0WeFQHiPQ2z28ZUf1YefMNwJ66r9KEURq6e04kQMHVNM68BecrFWixD3pdQeyiQ4kj8niOqzmgiklYSNAkWMivljAHm/ImQVvwhPknQoEIWF+UuEPe1KF7uLjP4834xG/ETM
cmptk+/yrZE5gdb/xkmnt4mIAWLCQXkuMkEcmGW8LU6ku5EtBhXCCcFCirdpsIxkrsLytJX1J3QeguxxcdseA6hWUtCDzAVxSqCNcOnahp5WHMGhsyQejM4Kp4JGjOcCctO1lAJdwZGMn+E8aNHwTiolL
sByv78ehOGkHOgXW6OAvgfWrl3o59NAwwaUuWX+/jeKgne5cfTZ14X5oEC9qGwaTehw893AhLkuA3FOKBCvP+/jK8fpxIV90GIFJOKk6Xqd12FUq8AC1V25aDv+6Wv+oRQrXdHEebjnef0Jg/F1+yXEwa
Ap5hI9XfNqNPJKJjKWfCCVOc4V1179c3yMaXfL+6ehA1SUz8CPw5ECHCK7H169N/vqF74dxzTpD8mkDI991PvV/8EBhSmvPhlBT+5sRYldUAppysgUHKkGvMnyKUkYROFuoEgVNqNUsMqtIiO2RDiNJ7o
bJJ7oNePxYb7BcLxmnYaOIibcrVEUhv1becOywid0BFHQiGadOepybntZ2Hf9kdAYZcI9ZICkS0DxBrxg79Z7H5nkPdRC4olPSAgCQDQ5IKmBHkzVn9c5RCdRadtYxbccmnSFaOB/ArRCP/2IlU9qHBSy
g9/A3tE/I1p0oz813+v9hCQzdaQlfdoUrumz36Jzc0ohuUUeZ7Majl4C8nuIdC3JpdPxnoMcn17tVemELdcC+kyX3SY/uv6KHOZOLZTPDquM0FW7tINXVnvx0fdEUvgTagcIoPIOOfjmS2kgdOcWsSe7I
g7msIbygifO6maLOeMRy1GY6GVypm3KrdaBwuB4PC2+AuZSZPvOEk4to5VL/88i9r3Yox69VSa1DHfuX1hmS/ybZMUW+hxUBTLKQK1zM2hgdCd5Tw7YRSCBWum8SQNKV5YYQnSAIhs+K+rH4q8JlXJtwa
wjSYLbaHXy2AphEoei5YY+vf8Kx2/6u1NEer3iomuDN4IfzKzwHrm62+QxU+7oT48o1cw1W0DM+rNyT0RFpE2Lh5VZCu+zDJGelThFlISMui/RUJzMVuQvh7NcEfqXzHGx+kN4hMLueF311zsXSsAv7s9
RCOi1yO71SJgP6KpfG+3IocscXKbrWEhEDEhmeJ+9phHH9Ro83NUrkg0rePRYc5Vsp9ybo5zWNQu3PtjigN+OWYG4F/519k4iFqUh0a3OcvDovfR/EAKcowKaRwlIDvJtlbMGKIsRCpp0oB+1WY9kRR9R
D2rjR3WNSIWclP+45R0VkQu842scQQvwJS6tD1UQ1D4q6whr01cYvPcqLAPW32O7yJdViA2mkq+zSD+sRD1T72AAzgnLUTYJWGFY9yW2DKZsYmdoWBuDRq3DFPh6lok1q8BIWHAmO2hOAywhJlM7W15oZ
f3Z0DG2UJj8+VQkEErbKaN6AHG8Tbwc2Cff/fU/ICZ0clljsLLmBCKjUKNlZ0zhjZoglS0ISEqfdi5CiMiKdYlAWjLr5ZCAPtaTNWSkffQTlKULMCtrCUyb2Ir8zx+AFfBAon7hMiatlmOQoT9VUd2cQj
P7JKEJgoxY9kAiLx2x9d29i9YgFqbaRHB5GSXZf6V4GaLXx2xmCJA5/k/QXREQG3cIxcEbmn9IaafUPV4BcOizg3VwPMFc/k7zBfwMaqJAWZwBwp8LcF3EVi20pIellQR7cLgPIPDvpVilavDeUjJZ27B
lsI1PYQUlkBQlWbu+Lu0XtMDSBSxvz2Djy0muCqirHTm1MS2WcnZq9P3HgiGWw8gHsydqv7nNvFwzH2Vd4674O4CChHUmHzcEgxi0Yz6yTxaWdb9TE7lSqoZ8hsh7tYvIr8pnfiQ6iaSDuept1hc7pg3s
vXWEki/wfcc+CaTz0/J+J7o9AoHnzgBJ4KI8Cz3tS0rmxhQqOqGbI2esYAtN0slJwxt7s42LTGYKw4T4U8zcPCUBYBeZgWBuRcGlnTAe8MuVdz39W3YsZwr1xehyDtmVdxxtX8/iCoW6nJ5RUeA7DFplu
IzJthAAJDa1BNBHVZ/HsDW+wIH7xUUQmmWxrnsSoNwY0ej0McMF3UIAqEpHTw8d0i+d09seJHsI+spHHqzgjz4JwFHErkRRDYtPsFclynNBnJdHc31Cm4vnKreKm6GdKmgAznxb04sKuU6Yj20WW4L9V/
xc2YBnoOUJaDWM7edaoiPoNeAL85SDWcqsWKBZ1XpO/vYr4cqawivZFFGFANzkYMYwPBTAJ40KGYbP4cQRNbbCTxpzegMVoUp6RhZ4CaFW1BJ7a0DcDj96jUsScDFdkCFBlOM4ObR0UfZkei+6LyG7Wyq
wlVumCUaaeKEaLtwbHSEfZJ6akDPMyj6Ax2h+u2uEfa0C5I0XXpAPCyDQSEOKecRFlVvFfxTS002AbBylP3DEHP8sea0H2pp56h0roCxUNGSeoigWSjLaVn8/7MIul72sd+DQIyR3Sc+E9f4rZ22I2cYx
EppiUatYAfmwzh7JakhRPMYjhs0OekGCtWj3M9RpYVY/YOC5b1LqRlRGZZwVq/2LPZohZTPr63yWZZIQC450GhTvBw3g1ayC/ybeA4hRSuahxRcHAbEgdwFluspqAqQaOvMgeBjOjV8snncVSFjBzB7yE
6z36Q60o3StAQs0lF101DEAn2cbn0/KR447iqvQnaJk5osXzkSS2eEucdzDS0y/9PdIxhYSJCuD8YhTN8aD5eS5E9e5EVNR6dDIQyAwRoLqIEpi6Jzcu+OqT2IN0cqMTMY+GRRinLO2wtUYnjWl1OnRI6
6MNAcuiIJ48X4eU/B9n2diD6W6QVHtVmO4zGH1Us43j9RtXv01s3g7s+J//fNnQw+MPzj31vOjG1DdahvNbYDYFc+HFvqJenqvN3Pf8dabqYsW4hcYUD7KybyaG6j3igwuHVgxhyAuYRItFhwzVi9094n
fadhxFl3IdVX1cKPngPYTsHBYtN7PePFr1C0/SJO238vxvThVm8fYBQjUBkuJa0gZ29ccjNrk4fic87Fj78C3TqyCBZQkZjIVmEDzjpCNo2r4Od0C3Amq2nl4Ap/yXi5dTpH/ZSNT9p5a7sTEA4msZVga
fKSCcZCxnyyxs+7uoOvawvmpozfYRSIa37DCdkFNitZpSjxJUbyaXHiE7kdqHcfztFMCUALuyQlazUBapzwWeI1SvrEjtw+ZZSiGR7b8AWZmOicV79ECG0AgyGCFKOmS/ZdPCvGuN852athqi82kv7sIi
VOM8IKbkfZuqZMXm1YqMGb6jZOMYbhO0DSjbi1FBD9ZzSMb4mVbLeet1AWIdQxw2xrNVNUeHwvtZeDydZ26jtV626BcgJcZCDySK4zDq7wAo2TtNeVJc1isPVPF68C9awhIRvkvqI8gyHLw1TE+OB9Fnb
o5I4GXc4b9App4ZOJv14C3nl0payv6ZD37WMb+NV8qZVIdwyF9Z2EaoJAjesoaCSVP72netNJNyt7+46xpGdk5iOqNNZcncuyHCH8LtcdUNSqx1oZufdzSNcMATkZ2xW5Ocfqz7r7XJRSDaPs+BIfTSMS
RuhrIMmM+xHIAo6iar/xhGTlChTFEePwuhdRUm0XX9IhO9jFtKlEWJ49AzjwQar3AFGKcCc1vccOoHuVbX/X5HboBJU4wjeoHaR0ea6fjoBeCxwwAEExqgNoMBiliQTV2iXxsSKfrrrs/u5HYMIQ7v9TM
ETfnF4wUYIYEmtiTWuATxa2Yw2Q8lQJYHRiTVEJipPJNMtRna4DhFrUVGeA8EafRleJdfioavg3+LmgY9gXNlgTol+WXSp+U3lfGNTPHk8xFxGIysCrnRmSno2gIqJgpsDVjV6aYlKGBn++kKNuy8is4n
i1f6SeknyNOzO3yQlsxcFcnDZQWk0aAli5w3BKsitZxXWJcgK6NTsr1Ct5X6kKpk6hhrkWW8s2Tp+1KrRIWo5N79zczda6IaVSYZItsTT+6kP+Wrcozc8z8crdIlo2LHT9hKrvWXottUloFWl2+5oSQhN
xbTiXUNdjrbxOtmmzEiJgcgVhI8qm9yXkwBeNZuH4oIj9JXkxBcR6NJWWM2R1d2UmssIuzz/s09uCX8WXnUnoyv2y0XXuG+izSZAGmyG2p6890o22SByT5pde1eBMQz38IEi60kOrwsmSyqpQv2OQxgbe
75ahgh5cAd52J+a/dk3ORQg5nHyXFzSzhxWuj0bozYT9WoeJMLHMDVxwDAa7oDrHERi3OtM5vMzm+PnRg+Y7oQZRKnIbJc/gGq+FUlkvsN2/tYhFiGbCn7xki5nasDNMDVHxZg1TjaAmo7jdd7D2BT4wo
cXmLvp8NXqbbZOM1CgfHWWMCPw0tS8pC1f+umGVP4AhbjRwxfxIUTAhEk1gsHA6Q88ThjyQRtBuKZlhiv2GkE1RZQrNC8ex9bO3HZaBemKuB5zSHq2ELMZrGkhlBwJF5geBVpShTUG6Mt+3p9wk9DYiXb
kry5dqSwmfxOAP6PBAMQX12/oYKwN0H0zhO1SnPnkZ8RvsFkmAMwjIFgFNigUz3maO39NVMRaoOQ84TqhYdBp3u9pKTmQXEjy4FB+ulG8NR3QLhIuzcn+oNZeCQ16p5v9UN9knBqYunMGJquHvPlS5DOu
VYqLhvytX54SACeRWFh09AwJbEzN4Uhr2N0rCIbpDAQZfUOZxwDphPbrpHAYZZj57Zk3kn/zZSDWGZaEt6DBqBO+EvSWeQPqbp/U/FnWCXWcY5dBU6rLWkIOVN6r+ayF0jqnSFcmZNiefx5KyJHelfyCp
OCuA0UCZvgfgEE7KcLPDeKWHb6a0OuvgYB+WE41YdOroKfluqFLgpbEILzkjKl/Da3mZmg5wYyljWD4HDGlfjvg1bZyDeg4B/8PP9Qw6Loiw5KS9Yl40AdYO05YaSvMHWxT7nOz6yVYkfIC/t17bbEpb2
pVxxNo56gsrAoUie0/WTAM0S3T+OkEzUmi/XoVDn/mQfdmxoJvYoKhishpkTv6SCYFD7Wb9bqrnMC5IflwU2jPhZSQUT4yE
Any help would be appreciated.
Re: PHP errors
The "Undefined variable" messages are just notices and warnings, not as severe as errors which typically will stop a page from loading. They can be safely ignored.
As for that page, it is encrypted as it is a core part of our product, hence the jumbled mess of characters.
