Getting Error While Installing
rlinux57
Post by rlinux57 »
I'm getting below error while installing log server.
Kindly help me...
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'sourceguardian'
rlinux57
Re: Getting Error While Installing
Post by rlinux57 »
Is any one there to help me.....
Post by Box293 »
What server OS / version are you installing it on?
Is this a freshly built server or are you trying to install it on a server already running other applications?
rlinux57
Post by rlinux57 »
centOS 6.6 and it's a vps and some websites are hosted in it.
Could you post your install.log file so we can review it?
rlinux57
Post by rlinux57 »
I have resolved the issue, please marked as close.
