Exclude specific tablespace from check_xi_oracletablespace
wesmith1017
Post by wesmith1017 »
So, I'm new to this particular monitor, but I'm curious if there's a way to exclude the TEMP tablespace from the Oracle Tablespace IO check. It works fine, I just don't want it to grab the values for TEMP or alert on them. Any thoughts?
check_xi_oracletablespace!--connect 'SERVERNAME:1525/HAEDEV' --username '********' --password '********' --mode tablespace-io-balance --warning 50 --critical 100
abrist
Red Shirt
Re: Exclude specific tablespace from check_xi_oracletablespa
Post by abrist »
I do not believe so (other than patching the plugin).
wesmith1017
OK, thanks.
