Hi Team,
Since notes_url and actions_url are not available on NagiosXI interface, We would like to create 2 URL actions under "quick actions" to get these informations.
Is it possible to get the standard Nagios macro $SERVICENOTES$, $SERVICENOTESURL and $SERVICEACTIONURL$ available for url actions ?
Best Regards
actions component macro
Re: actions component macro
You can try the "new" version of the component. Download the file below:
don't unzip it! Install it as you would install any other component in XI:
Admin->Manage Components->Browse->actions.zip->Upload Component
Then configure it by using the %notes%, %notesurl%, and %actionurl% macros in order to display the links under the "Quick Actions". See an example below:
Let me know if this helped.
It works. Thanks.
You can close this topic
